2010 mercedes glk 350 lost communication with IP
Old Jan 21, 2023 | 03:04 PM
TomMc's Avatar
2010 GLK 350
I have no cluster lights what so ever. Car runs but dash is dead?
Old Jan 21, 2023 | 04:42 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
First thing is do is check fuse(s).
How's the battery? New or aged?
Is the cluster off when you insert key and turn to ON position, prior to startup? Or only after startup it's black?
Old Jan 22, 2023 | 01:44 PM
TomMc's Avatar
2010 GLK 350
Battery is fine and the cluster is always dead even prior to starting
Old Jan 25, 2023 | 12:22 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Check for power and ground. If both are there, you will most likely need a new one. Used can be successfully installed and programmed.
Old Jan 25, 2023 | 06:36 AM
TomMc's Avatar
2010 GLK 350
Turns out fuse number 27 I believe was loose ... all fine now .
thank you.
