HVAC Fan - Works Ignition on but not with engine running
Old Mar 1, 2023 | 03:37 PM
SilentSmith's Avatar
GLK250
The HVAC blower in my car had been making a chirping noise on all speeds but high (7) for a few years and finally died yesterday. I picked up a replacement 'four seasons' brand as it was first available and came with a warranty. I swapped the fans out and here is where it all get weird.
With my ignition on but engine off, the fan works on all speeds without any issues or difficulty.
With the engine running, I have no fan at all. I can change the speeds but there is no response from the blower motor. If I turn the car off and put it to ignition on the fan again works perfectly.
Anyone have any insight? My thought would be that the resistor module is fine as I have all the speeds available when it works, I don't understand how the engine running would change the power source to the HVAC blower.
Old Mar 1, 2023 | 03:54 PM
Mmr1's Avatar
2013 glk 350
A thought is to check the connections against the old fan, make sure it’s wired the same and pins actually connect. It’s probably Chinese made . If it doesn’t work get one from a reputable company like FCP Euro.
Old Mar 1, 2023 | 04:23 PM
habbyguy's Avatar
2011 GLK 350 4Matic
There could be an odd failure in the new fan's circuitry ("regulator") that prefers 12.x volts to 14.x volts (failing over some threshold voltage in between). You could probe the connector to find out if the 12 volts (or even the ground) disappear when you turn the ignition on.
Old Mar 2, 2023 | 01:41 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Agree with “weird.”
The blower motor, resistor, and controller are probably okay because they all work with the key on/engine off.
Maybe a high end scanner that can read HVAC codes would show something useful.
Old Mar 2, 2023 | 10:11 AM
habbyguy's Avatar
2011 GLK 350 4Matic
Originally Posted by Odd Piggy
I think there is a component (electronic relay, maybe?) on it that switches from alternator to battery when the engine is not running.
I've never heard of that, though I don't ever put anything past BMW's engineers (kings of over-engineering). ;-)
But I can't imagine how that could even be done, given the alternator output is tied directly to the battery.
Old Mar 2, 2023 | 10:35 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Is there anything else that stops working when the engine is running? What is the system voltage when it's running?
Old Mar 2, 2023 | 11:10 PM
Odd Piggy's Avatar
Originally Posted by habbyguy
. But I can't imagine how that could even be done, given the alternator output is tied directly to the battery.
If you're sure I'm wrong, I'll back off on that. Don't want to misdirect someone.
Old Mar 3, 2023 | 01:16 PM
KanataSteve's Avatar
2013 GLK350 Canada
Many of you might have seen I had similar trouble with mine and solved it all by swishing it in an alcohol bath to rinse off the carbon grit that came from the motor brushes. Fixed everything. I also saw an inductor that was * very * close to the motor frame with carbon all over it, so I pushed that over a ** tiny ** bit so it had no chance of touching a ground.
Just make sure to thoroughly dry it for quite a few hours before reinstall - alcohol is quite flammable.
The dealer also did this in a Smart car recall- they had the same issue in those fans, but didn't do an alcohol wash.
Old Mar 3, 2023 | 01:31 PM
habbyguy's Avatar
2011 GLK 350 4Matic
I finally chased down the schematic for the GLK, and (happily) the MB engineers did seem to do the traditional thing. ;-) Sometimes they can surprise me (though I doubt as much as the BMW engineers can). ;-)
The battery, alternator output, and starter are all tied together at the "main battery buss", which is typical since it's very difficult to fuse these items without causing a whole lot more problems than you are potentially solving. I do think there's a pyrofuse inline with the battery, though that only comes into play after a serious accident, and won't affect anything at all until it's blown, then nothing will work (due to the fact that the battery is now disconnected).
