GLK350 won’t start (battery recently replaced)
Old Apr 10, 2023 | 08:56 PM
Blown63's Avatar
2015 CLS63 S-AMG
Anyone ever experience this before? The car will eventually start but could take 15-30 min of trying. It does this weird thing where it acts like the car is asleep and then wakes up again. Watch the video where i actually get it to start but it dies right after it does. I changed the battery last week and drive the car after it turns on sometimes so I know the alternator is working.
Benz couldn’t figure it out either since it isn’t throwing any codes. Thoughts?
https://youtube.com/shorts/UbcxSc7bfPU?feature=share
Old Apr 11, 2023 | 05:48 AM
Mmr1's Avatar
2013 glk 350
Link does not work .
Old Apr 11, 2023 | 08:55 AM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
@Mmr1 ... video plays for me.
To the OP, was it starting up as normal before the battery swap ?
Old Apr 11, 2023 | 09:00 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Originally Posted by Blown63
It does this weird thing where it acts like the car is asleep and then wakes up again. Benz couldn’t figure it out either since it isn’t throwing any codes. Thoughts?
Just a thought — The car should wake up when a door is opened. If it doesn’t, or if it’s asleep when it shouldn’t be, it may be the quiescent current relay on the pre-fuse block. Along those lines, though, I have never see one fail and I don’t know how to test it.
Old Apr 11, 2023 | 09:37 PM
chassis's Avatar
2017 GLE350 4MATIC
Battery
Spark plugs
Ignition coils
Starter motor
Crank position sensor
Fuel filter
Fuel pump
Fuel injector
Old Apr 12, 2023 | 06:40 AM
Mmr1's Avatar
2013 glk 350
What is battery voltage , a new battery doesn’t mean it has proper voltage , it does sound low when starter engages ,maybe a bad starter?
bad key fob? Try different One . Maybe corrosion on a terminal or bad ground somewhere. Have a local mechanic go over it , hopefully it’s a simple cheap fix. It could be many simple things. Is it an AGM battery? Charge it up and see how long it takes to charge, but use a charger with the AGM cycle. New batteries often come very low on voltage if they have been in storage . Sears once sold me a battery that took a day to charge , I was so mad I got the battery for free!
Old Apr 12, 2023 | 09:06 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Instead of looking for a code, they need to look at what is missing. To start, certain conditions must be met. Something is missing...
Old Nov 23, 2024 | 03:42 PM
Petethepug's Avatar
90 VW Corrado g60, 07 New Beetle Vert triple white & 09 Escalade ESV Plat LOL!
Pretty sure there’s some kind of ceremony you can do on a full moon Thursday that determines what’s going on.
Old Nov 23, 2024 | 05:49 PM
calder-cay's Avatar
Originally Posted by Petethepug
Pretty sure there’s some kind ...
​​​​​​(annoying GIF image removed).
Great contribution ... resurrecting a thread from over a year ago ... user Muted
Old Nov 23, 2024 | 11:42 PM
Petethepug's Avatar
Did that just for you@calder-cay . Happy Thanksgiving grumpy old man!
