Radiator Leaking
So my question is this? Are there more than one radiator and is this something someone can do as a DIY? Should I put any radiator sealant in system?
Also, do NOT put in a sealant. That's just begging to have REAL problems later when it starts clogging up the heater core and messing with the pump.
I'd suggest one of two ways to determine where the leak is... First, you can just trace the white residue up to its source. Second, you could add some UV dye (available at a parts store) to the coolant, and check for "new leaks" with a black light (should be pretty obvious). Only then will you know what the best course of action is. Could be a bad hose, loose / bad clamp, bad radiator, or even just a slightly open drain valve.
It looks like it is leaking from the metal clamps that are attaching it to the plastic. I looked on line and did not see anything about removal of radiator. Any ideas where I can get the steps? It looks like it is time consuming. I will not add sealant.
Yours is a 2013, so it could be a little different, but here's a link to a helpful DIY (never did it myownself, so have nothing more to add)...
https://www.pelicanparts.com/techart...eplacement.htm
That means it has zero evaporative emissions, and therefore special components to achieve this.
Enter your VIN into lastvin.com to get your data card. A PZEV vehicle should have code 917 listed.
You HAVE to remove the tranny lines from the radiator when replacing it. I simply undo the nuts, pull the line away, then plug the end of the line. I usually use a small stick of wood shaven like a pencil. (I have actually used the sharpened end of two pencils
). But anything will do, such as a rubber plug. It's not like tranny fluid is gonna come gushing out.Then remove the various radiator securing bolts. Then remove the coolant hoses, plus any other lines.
Pull rad out, insert new, then install tranny lines, hoses/ etc, then securing bolts.
Both jobs took about an hour for each.
Over the years MB has used a number of different ways to connect these lines. Some are screwed right in as described by @calder-cay . Others are quick connections with sleeves to hold the lines in place.
Either way, if you completely drain the radiator, there shouldn’t be any concern with getting coolant into the transmission lines.
BTW — Do this work with the engine completely cool. And wear nitrile or vinyl gloves, not rubber. Ethylene glycol coolant vapors and liquid coolant absorbed though the skin can cause kidney damage.
The clamp is either at the reservoir connection, or at the radiator connection side. Let us know ... in the morning, I'll go out to our 2014 GLK350 and check it out.
Check photo - it's a zoomed in shot of that hose, with arrows pointing at the securing clip. Personally, I'd classify that as a circlip. And yea, those clips are spring-loaded, so I can imagine one zooming off.
I would think that part is available at the dealership or maybe FCPEuro.
https://www.fcpeuro.com/products/mer...des-0009931202
I agree with buying new hoses, I already have easy access.
But then again, I have no idea on the GLK.
