Torque specs mercedes glk 350 2013 4matic
Glk 350
Hi if someone can help I would like the torque specs for the following components:
Front strut ( all bolt torque)
Rear lower control arm torque specs:
Rear shock absorber torque specs:
Which rear lower control arm?
rear shock- 3 top nuts+ 35nm. Bottom nuts+ 55nm+60 degrees.
Front strut- 3 top bolts+33nm. 2 nuts at wheel carrier+100nm.
At least thats what I have for info.
Front Sway bar links-98nm.
Not really sure what you're asking. All the bolts are visible in the photo. From right to left they are: rear sub frame, shock absorber, sway bar link, and wheel bearing carrier. There are no struts in the rear suspension.
Glk 350
I know there's no strut but I'm asking for it cause I'll do the job specially for the strut mount torque spec?
