2015 Glk 250 front wheel hub torque
Old Nov 24, 2024 | 02:01 PM
Derk#10's Avatar
Hi there, I'm new to the forum and am just looking for the correct procedure for re torquing the front wheel hub bolt after replacement. I know when I removed it with my 1/2' impact it sure took some power, it must be torqued well over 200lbs??
Any info would be greatly appreciated.
thanks
Old Nov 24, 2024 | 04:03 PM
Mmr1's Avatar
2013 glk 350
Do you mean the rim , wheel, that’s about 110lb
Old Nov 24, 2024 | 04:06 PM
Derk#10's Avatar
No this one
[img alt="The centre one
"]https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x926/20241124_112518_a8844fa548190be693d5970c54df8f53a6 eb24b5.jpg[/img]
The centre one
Old Nov 24, 2024 | 04:38 PM
habbyguy's Avatar
2011 GLK 350 4Matic
If it's like the pre-facelift (2010-12) models (and I'm pretty sure it is) you torque the axle nut to 88 foot/pounds (120Nm) and then rotate it another 90 degrees.
Old Nov 24, 2024 | 08:08 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
You mean the blue bolt, right?
For my 2014, probably the same as your 2015:
Stage 1 - 160Nm
Stage 2 - loosen (Just enough to take off the tension, maybe 1/4 turn)
Stage 3 - 120Nm
Stage 4 - 90 degrees
