2014 GLK 350 4Matic x204 | COMAND failure - possible CAN gateway issue
Old Jan 23, 2025 | 07:59 PM
ken h's Avatar
X264 GLK350 2014; W211 E500 4Matic 2004; W124 E320 1995
Hello Good People (hopefully including @CaliBenzDriver
My COMAND media system has failed - I think it may be CAN system gremlin: bad capacitor, ground fault, or perhaps water ingress (ground fault). There's no indication (water at fuse boxes, cabin smell, steaminess, etc) of water entry anywhere though.
I pulled the codes below using a Foxwell NT710 because the entertainment and media system (COMAND) started to cut out then restart. When the COMAND restarted, however briefly, all functions were fine. Now the COMAND does not start at all. The display and back-up camera are dysfunctional as well. As occurred with @Jasien139 , I have the Own button cycling light (one 1 sec, of 4 sec) when the dash lights are in (dusk).
When the driving lights are on (ie. dusk to dawn) the COMAND "On" button on the volume dial is illuminated, but it pulses off for 4 seconds then re-lights for 1 sec.
ECO is unavailable: the green ECO light comes on in the centre console button in Ignition 2 position, but when the engines is started, the ECO light goes off, and remains off. ECO remains unavailable (see code U113800 below).
Tests Performed
Before COMAND became completely dysfunctional, built in Reset performed using the COMAND rotational controller. That device also works fine: Foxwell's active test features showed putting press and rotation tests are correct.
All fuses are good: US :HD model so front SAM is on LHS in front off driver firewall. Aux battery is 12.85v. Main battery is 12.47v after sitting overnight.
Both batteries have been disconnected to discharge system capacitance and reconnected. No change.
Thanks you for your insight and expertise.
CODES FROM FOXWELL NT710 (also attached)
VGS-Transmission control
U113800 | Stored&Current | Communication with the electric oil pump in the transmission has a malfunction.
ESP-Electronic stability program
C257200 | Stored(Event) | No CAN message was received from control unit 'Combustion engine' or 'Transmission'.
C258600 | Stored(Event) | No CAN message was received from control unit 'Combustion engine' or 'Transmission'.
C252400 | Stored(Event) | One or more messages transmitted by control unit 'N93 (Central gateway control unit)' via thE CAN bus are intermittently not available.
C221500 | Stored&Current(Event) | One or more signals sent from control unit 'A1 (Instrument cluster)' via the CAN bus is implausible.
SRS-Supplemental restraint system
B1CE801 | Stored | The digital output for the crash signal has a malfunction. There is a general electrical fault.
ZGW-Central gateway
P061000 | Stored | The coding of the control unit is incorrect.
U118300 | Stored | The diagnostic CAN network management is unstable.
U116000 | Stored | A bus keepawake unit was detected.
RFK-Backup camera
U118587 | Stored(Event) | Communication with the control panel
HERMES-Control unit for telematics services
B142E31 | Stored(Event) | The GPS antenna has a malfunction. The signal is not present.
