Battery Registration / Coding Necessary?
Old Jan 27, 2025 | 05:58 PM
42R's Avatar
42R
MB ALL DAY
Question Battery Registration / Coding Necessary?
Recently bought a facelift 2013 GLK 350 4MATIC
Had an original MB Varta battery that was getting weak,
went ahead and replaced it with a new AGM battery (boy does it crank / spin over fast now!)
anyhow, i was under the impression battery coding / BMS reset was required following the main battery replacement,
I bought an ICARSOFT MB V3.0 scan diagnostic tool thinking it would be able to support something as simple as BMS reset
but ive been tooling around with it for a while and can't find any service or diagnostic function that will allow for a BMS reset / battery registration / battery coding
I found a "funciton support list" document on the icarsoft site for the MB v3.0 but doesn't seem to mention BMS system anywhere there either.
Does my icarsoft mb v3.0 not support BMS communication, or could it be possible it doesnt have a BMS and therefore, no need to perform a battery registration at all?
i emailed icarsoft to inquire, but figured i ask MBWORLD too.
my GLK FIN is WDC2049881G036175 (204.988)
Old Jan 27, 2025 | 08:30 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Your Mercedes GLK does not require battery coding. You are probably going to get someone who disagrees with me. However, we have a small fleet of cars and trucks with over 20 years and 1+ million miles on the Benzes and we have never done any coding or programming after a battery change.
Old Jan 27, 2025 | 08:32 PM
42R's Avatar
42R
MB ALL DAY
thanks! i found one post when searching on here confirming this to be the case on X204, but surprisingly, i did not find many other posts clarifying this matter at all.
this could very well explain why battery coding is not an available option in my scan tool service list.
Old Jan 27, 2025 | 08:49 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Bad "confirmation". Might show us that thread.
Correct. Not required for either battery.
Old Jan 27, 2025 | 09:11 PM
42R's Avatar
42R
MB ALL DAY
by post confirming this, i mean to say, confirming MB not requiring battery coding like BMW.
i went through a lot of battery discussion threads, ill need a few minutes to dredge it up.
Old Jan 27, 2025 | 09:30 PM
calder-cay's Avatar
"coding like bmw". Not sure what a bmw is. 🙂
No need to dredge it up ...
Old Jan 27, 2025 | 10:56 PM
Odd Piggy's Avatar
I’m sure that wasn’t serious, To us BMW=Money Pit. One 335i Cabriolet was enough. The CLK500 Cabriolet Benz wasn’t far behind, though. Maybe “cabriolet“ is the common factor???
Old Jan 28, 2025 | 03:27 AM
calder-cay's Avatar
Yep - definitively not a serious statement or opinion ... why I inserted a smiley👍 Heck, in the Honda (motorcycle) forums, it's rare I comment on Harleys 🙂
I will admit, though, we can't assume car maker xxxx does the same thing as car maker yyyy, especially regarding electronics. That's important!
Old Jan 28, 2025 | 07:19 AM
Mmr1's Avatar
2013 glk 350
Code a fkn battery ! A bmw scam to make the dealer his boat payment .
Old Jan 28, 2025 | 09:49 AM
andreigbs's Avatar
GLK 250
Our GLKs don't require battery registration, or "coding" as some call it, when replacing. Many BMWs, however do, including mine. Not a big deal if you have BimmerLink or some other good scan tool app.
Old Jan 28, 2025 | 01:44 PM
KanataSteve's Avatar
2013 GLK350 Canada
I've never done any coding. Not sure how or why you'd do that in any car for any reason. It's just a friggin' battery. Great way to pocket some cash though.
Old Jan 28, 2025 | 02:25 PM
Odd Piggy's Avatar
Just as an FYI - on the 335i not registering the battery resulted in the new one never getting more than 80% charge. Not that big of a deal because everything still worked fine. I found that on routine maintenance with my electrical system analyzer. Asked a friend who owns a German car shop and he said register the battery. My old scanner was multi vehicle, under BMW was Register Battery, did the 4-5 steps and a few weeks later, the battery showed 100% on the analyzer. So for Bimmers, I guess that's a thing, and MB BCMs are just a lot smarter.
Old Jan 28, 2025 | 03:36 PM
andreigbs's Avatar
GLK 250
Some mfr's added this parameter because batteries range in type and capacity, allowing owners to purchase optional sized (capacity-wise) batteries other than what was installed at the factory. While some may not think a 5aH or 10aH rating difference is significant, or a 800CCA vs a 900CCA battery requires different charging algorithm, the charge levels from some Euro cars' alternators need to be told what capacity the new battery is to charge it accordingly and maximize the life of the battery.
As you know, some cars' electronics and gizmos continue running in the background even with the engine off and the doors locked. This places different demands on the battery than simply starting the engine, and when you add stop-start function into the equation, things get a lot more complicated. Therefore, if your Euro car allows you to register a new battery it's a valuable method of getting the most bang for your buck with that battery.
As previously stated, MB doesn't need it (pretty sure Audi/VW doesn't either) but BMWs, Minis and perhaps others certainly do and it provides you with options on what batteries you can buy when you can't find the exact OE type.
Old Jan 28, 2025 | 05:29 PM
42R's Avatar
42R
MB ALL DAY
i think it might have been some of the first results on google that led me astray on this topic
Old Jan 30, 2025 | 05:22 AM
MBKLUE's Avatar
Yikes:
BMW - Inventing Complication.
