2011 GLK Glasroof stuck on one side - won't open!
Old Apr 13, 2025 | 05:38 PM
GLK-Alex's Avatar
2011 GLK 350
Hi,
When I try to open the glass roof then on the left the rear portion lifts and tries to move backwards. But on the right the rear part lifts only a bit (half as high as the left side) and the roof seems stuck - can move anywhere, especially not backwards.
The roof might have been closed for years.
I applied LOTS of pressure (with my fingers while I operated the switch) to get it lift more and get it moving backwards - to no avail.
Is this a known problem? The car was all its life in California (now in the EU). Might have been closed for many years.
The roof will close by itself.
Old Apr 13, 2025 | 10:56 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Originally Posted by GLK-Alex
When I try to open the glass roof [sliding panel], on the left [side], the rear portion lifts and tries to move backwards.
But on the right [side], the rear part lifts only a bit (half as high as the left side) and the roof [sliding panel] seems stuck - can [not] move anywhere, especially not backwards.
I applied LOTS of pressure (with my fingers while I operated the switch) to get it [to] lift more and get it moving backwards - to no avail.
Personally, I would NEVER be forceful with a sliding panel issue. Why? What if it then jammed in the partially open position and doesn't close (?) Now you have a much worse problem.
The sliding panel, to my knowledge, has various sensors - have you used a code scanner to check for faults? There's also delicate wiring in there that is easily compromised.
(it's not understood what the photo offers)
Old Apr 14, 2025 | 05:49 AM
Mmr1's Avatar
2013 glk 350
I would try using a mirror and a camera to see what’s broke or jamming it . Maybe a vacuum or having a mechanic blow it with a nozzle on their high pressure compressor might help .
if your lucky it’s debris , if not lucky it it just stays closed ! I think a broken part could be too expensive to repair. Or maybe a code was thrown .
Old Apr 14, 2025 | 07:29 AM
GLK-Alex's Avatar
2011 GLK 350
Thanks!
