Need advice on lowering springs
Is this a legit concern, and does my GLK look as if it's settled? I believe it currently has around 3" of gap. Thanks for the help.
You wrote that you have not yet installed the H&R springs. Does that mean you still have the original GLK springs from the factory? If so, you can be certain that the springs have "settled" after at least 10 years.
"Sport" springs generally should be stiffer AND lower/shorter (to lower the center of gravity). If a sport spring is stiffer but the same uncompressed height as the standard spring (also when uncompressed) then it will raise the ride height of the vehicle above that of the standard springs - raising the center of gravity.
Also, sport springs can hurt handling and braking if you're driving on bumpy, undulating, curvy roads. You can end up losing grip at spots or even complete tire contact with the road, at times. They don't always provide better handling. Depends on the driving circumstances, among other things.
