GLS Class (X166) Produced from 2016 to 2019
AC and a high idle
Old 07-17-2018, 11:21 PM
Armanidog's Avatar
2017 GLS550,. 2016 S550,. 2018 GLE AMG Coupe, 2017 C300 Convertible (traded), 2017 SLC300 (traded),
My 2017 GLS550 runs about 800 RPM with AC on and about 500 RPM with it off. This is in Phoenix with outside temperature at 110 degrees. Also have a 2018 AMG GLE coupe and it runs about the same RPM's with AC on and with it off at the GLS.
Old 07-18-2018, 06:45 PM
jerome8283's Avatar
GLS450
Thanks guys. It appears this is normal as you all point out. Chuck123 please let us know if you find out anything different.
Old 07-06-2022, 02:53 AM
jehadfh's Avatar
2015
i have ml400 2015 i notes same issue when car in sun but in night idle is normal and ac on i try put some cold water to air sensor and it solved. the proplem in sun air sensor give higher tempreture so idle go up 4 tick
Quick Reply: AC and a high idle
