GLS Class (X166) Produced from 2016 to 2019
Brake pedal squeaking noise
Old Mar 3, 2021 | 06:30 PM
opelrsx's Avatar
2019 GLS 63 AMG
Dealer replaced brake booster, but still making the rubber squeezing noise when press and release brake pedal. Not from the brake, from the brake pedal travel. Maybe simply somewhere need lubcation... any tips?
Old Mar 12, 2021 | 11:20 AM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
how long ago did you come from the dealer?
Old Mar 16, 2021 | 12:20 PM
opelrsx's Avatar
2019 GLS 63 AMG
Replacing brake booster didn't get rid of the noise at all. Still there when I pick it up right after they replaced brake booster. Then they say it's "normal". I don't want to wate time going back and forth with them. Something they cannot fix or don't care to track down they will claim it's normal. Just like my driver seat also made squeak noise when going over bumps. Mentioned to them while doing some other works, three times, no fix, then was told normal... I finally took a close look myself, found a bolt underneath slightly loose, 5 seconds to tight it up noise gone...
Anyways, I guess probably somewhere need lubrication so just reaching out to see if anyone has any tips where to look at.
Old Mar 28, 2021 | 01:41 PM
opelrsx's Avatar
2019 GLS 63 AMG
Anyone?
Old May 3, 2021 | 02:02 PM
opelrsx's Avatar
2019 GLS 63 AMG
Video link. Tried B'laster PB-50, WD-40 liquid grease... still making this noise
brake pedal noise
Old May 4, 2021 | 12:56 AM
wyatt88's Avatar
GLS 450
Some say dirty calipers can cause a brake pedal squeak. Not sure how that would be a cause, but found it on a google search of 'brake pedal squeak'. Good luck, I hate squeaks and rattles.
Old May 4, 2021 | 01:23 PM
opelrsx's Avatar
2019 GLS 63 AMG
Very annoying... I tried to lubricate everthing around, cannot think of anything else. Only started after last service, which they did brake service. First complaint, dealer said they replaced brake booster, but noise still there, now they say it's normal... but no way that's normal.
Old May 5, 2021 | 05:35 AM
fabbrisd1's Avatar
A gaggle of MB's
What Year/Mileage GLS ?
If it under MB New Car Warranty - call MB Customer Care with a copy of that most recent service invoice.
PLEASE PLEASE don't spray 1970's lubricants in your MB... WD40/PB-Blaster/etc this isn't a rusty bolt on a '70's Muscle Car...
Amazon Amazon
Old May 5, 2021 | 07:44 PM
opelrsx's Avatar
2019 GLS 63 AMG
2019, still under warranty, they replaced brake booster once, now saying it's normal. I've sent the video to my SA, let's see if they will get back to me with anything new.
Old May 7, 2021 | 05:08 PM
opelrsx's Avatar
2019 GLS 63 AMG
Shop foreman watched video, He admits it's not normal.... booked in, let's see what they can do this time.
Old May 25, 2021 | 07:46 PM
opelrsx's Avatar
2019 GLS 63 AMG
Back from the shop, looks like they fixed it this time, nosie gone... brake master cylinder replaced.
Old May 25, 2021 | 09:49 PM
iridium18's Avatar
2023 AMG GLE63s, 2017 AMG SL63, 2024 Sprinter, 1958 Chevrolet Corvette
Good to hear of resolution.
Old Mar 18, 2022 | 04:10 PM
zaidar61s!'s Avatar
Gle 350d
hello there mate im having issues with my gle 2021 where the brake pedal makes a annoying squeaking sound
so you by any chance have a printout of what mercedes did so i can show it to the mercedes dealership as they havent even attempted to replace the booster yet
Old Mar 18, 2022 | 04:49 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I have what I suspect is the same problem, but your sound file is not publicly available.
Old Mar 18, 2022 | 04:52 PM
zaidar61s!'s Avatar
Gle 350d
Originally Posted by John CC
I have what I suspect is the same problem, but your sound file is hot publicly available.
hi can you check my videos. Does yours sound like this?
https://www.dropbox.com/s/6g4p0a4j2n..._3881.MOV?dl=0
https://www.dropbox.com/s/i3gvo4v5e7...%2054.mov?dl=0
https://www.dropbox.com/s/9a90levwml...%2021.mov?dl=0
Old Mar 18, 2022 | 05:06 PM
John CC's Avatar
I think so. My wife is the one who drives it most of the time, so I'll have to go listen again to be sure.
Old Mar 18, 2022 | 09:48 PM
opelrsx's Avatar
2019 GLS 63 AMG
I will post the paper when I find it. It was the brake master cylinder not brake booster. They replaced both (brake booster first but still making that noise). Replacing brake master cylinder fixed it.
Old Mar 19, 2022 | 12:26 AM
zaidar61s!'s Avatar
Gle 350d
thank you.. if you can attach the document it would really help
thanks again
Old Mar 19, 2022 | 02:01 PM
opelrsx's Avatar
2019 GLS 63 AMG
thanks again
Here you go
Old Mar 21, 2022 | 08:28 PM
zaidar61s!'s Avatar
Gle 350d
Here you go
thank you very much mercedes have ordered the replacement booster and master cylinder thanks to this.
apparently there is a back order on master cylinders so hoping it arrives soon
Old Jun 28, 2022 | 07:27 PM
zaidar61s!'s Avatar
Gle 350d
Here you go
hi how has your car been after master cylinder replacement? A month after my repair issue is back
Old Jul 8, 2022 | 11:18 PM
opelrsx's Avatar
2019 GLS 63 AMG
Slowly coming back I think...
