GLS Class (X166) Produced from 2016 to 2019
Soft Close Doors Not Working
Old Feb 10, 2022 | 08:23 PM
User12345678's Avatar
GLS550
Hello I have a 2017 GLS550 with soft close doors and I replaced my faulty soft close actuator as the cable was broken inside and after I installed the new soft close actuator I unhooked battery for 30 seconds and reconnected it and it still won't work, Mercedes then suggested to put new door latch in and that but that did not solve the problem. Couldn't find any blown fuses. But the fuse diagram doesn't show what fuse is for the drivers door door module.
Any help would be greatly appreciated.
Old Feb 10, 2022 | 09:17 PM
DoberdadinMD's Avatar
E350 Sport, GLS450
Briefly hijacking the thread - ours work but I don't know how to get used to them. Any pointers?
Old Feb 11, 2022 | 01:09 PM
JaTe's Avatar
MB GLS450
Have you tried putting a voltmeter to it to see if you're getting power at the actuator?
Old Feb 12, 2022 | 12:31 PM
skw's Avatar
skw
2019 GLS450
We're still getting used to them as well. I've learned to just close the doors gently and realizing it's ok if it doesn't latch, which is contrary to everything you know. My issue is that now I do the same in my other cars and have to turn back to close the door fully.
Old Feb 12, 2022 | 08:10 PM
E350 Sport, GLS450
Haha. I had the same issue with Keyless Go. I was always momentarily perplexed when the ML wouldn't open with just my touch.
