GLS Class (X166) Produced from 2016 to 2019
Largest tire size on a GLS550
Old May 10, 2022 | 04:15 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
What is the largest tire (height and width) you can fit on a GLS550 on the stock 21 inch wheels?
Old May 11, 2022 | 04:53 AM
Promo Bob's Avatar
AUDI Q7
Hi
i wouldn't know on 21s, but i can tell you 305/40/22s fit, and that's the max. Bigger will rub(in front@).You can try those online calculators "will they fit" to kinda estimate and compare. I'd say maybe a 275-285 45 21 will fit allright.
Hope that helps.
cheers,
Bob
Old May 11, 2022 | 11:26 AM
threeMBs's Avatar
Only MBs - the best or nothing
Theoretically, the largest tire that can fit stock's 21x10 wheel and have no clearance issues on GLS is 305/45-21. However, since there's no tire in that size (nor 295/45-21) the largest (tallest) tire is 285/45-21 which is narrower than stock (295/40-21) but almost an inch taller.
Old Nov 25, 2022 | 02:09 PM
SVDNN's Avatar
GLS550; Tesla M3P
We have 315/40 R21 on the stock GLS550 21 x10in wheels. Got tired of the the wife curb-rashing the wheels. Work very well for intended purpose.
All good except would be challenge to place snow chains (low profile)...not enough clearance.
Really wish there was a 305/40 option but no tire exists in that size.
You could probably get away with a 305/35 R21 on the 10in wheel but it is an inch smaller diameter and obviously thinner side wall.
Doubt the 315/35 would fit on the 10in wheel due to the smaller side wall compared 315/40
Hope that helps
