GLS Class (X166) Produced from 2016 to 2019
Engine air filter
Old Nov 10, 2022 | 09:28 AM
waterboy7898's Avatar
2017 GLS 550 4matic
Engine air filter
Is there any videos on how to change a engine air filter on a 2017 GLS 4matic
Old Nov 10, 2022 | 09:49 AM
chassis's Avatar
2017 GLE350 4MATIC
Yes and WIS is provided. Try the search feature or Google. From the looks of it, it appears trivially easy. Have you taken a look to see what work is involved?
Old Nov 10, 2022 | 10:02 AM
waterboy9878's Avatar
2017 GLS 550 4matic
Not yet
Old Nov 11, 2022 | 08:25 AM
clarkpittman's Avatar
GLS550, GLE450 Coupe
I just purchased Hengst air filters from FCP Euro (fcpeuro.com) for my 550. $45.98 for the two filters shipped ground. The filter change looks fairly straightforward 'except' for one hose clamp on the driver's side filter housing. I don't think all of the X166 models have the same filter housings though. It looks like it may be a re-useable clamp but I'm not sure as I haven't taken the time to start the filter change.
Do the engine air filters get changed with any of the pre-paid maintenance schedules? I can't find any mention of it.
Old Nov 11, 2022 | 03:13 PM
DBMC's Avatar
2017 GLS 550
already a thread on this ->
I did K&Ns in my GLS550. There are videos out there. It is not as "easy" as you'd think.
You will need to remove a couple of vacuum hoses and you basically have to turn the assemblies over to access the filters.
Be careful with those intake hoses. It doesn't take much for them to start unraveling. I actually used some foil duct tape on the one that I damaged.
GLS450 looks easier
Old Nov 14, 2022 | 10:35 PM
bakestein1's Avatar
2018 GLS 550
Not a reusable clamp unless you have the special tool. Fairly easy.
