GLS Class (X166) Produced from 2016 to 2019
GLS 450 Halogen High Beam
Old Jan 10, 2023 | 05:07 PM
bestexcuse209's Avatar
2017 Mercedes GLS450
I need to replace a high beam bulb. I can't' figure out how to get the bulb out. It does not turn easy like I think it should. Any help?
Old Jan 10, 2023 | 08:55 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Do you have active headlights? They're a whole different animal. On our GLK we have halogen headlights. One bulb twists CCW. The other you push up on the back end and it snaps out.
Old Jan 25, 2023 | 07:25 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
If it’s anything like my old ML 350, you’ll have to give it some effort to remove it. They can be a real pain to unscrew.
Old Apr 2, 2023 | 02:02 AM
007_e350's Avatar
X166 gls450 2017
I changed the bulbs today, turn them CCW and the whole bulb assembly with retainer comes out. Then you disconnect the bulb from the canister and harness, insert new bulb the way older one came out (note the little cut out aligns to the top 12 o clock), rotate CW till it locks. Then connect harness. Put the waterproof cover back on. Then the cover in the fender liner and viola. 15 mins
