GLS Class (X166) Produced from 2016 to 2019
Trailer hitch
Old Mar 9, 2023 | 04:55 PM
MBasheville's Avatar
GLS 550
Trailer hitch
I have a 2018 GLS 550 that I would like to put a trailer hitch on. Looking for suggestions
Tx
Old Mar 9, 2023 | 07:24 PM
masscomguru's Avatar
2018 GLS 450
installation doesn't look bad. They don't address any wiring requirements though.
Old Mar 9, 2023 | 08:41 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
What do you intend to tow? If it's light duty 2-3K lbs, a hitch and lighting adapter from e-trailer is probably the way to go. If you're looking at something close to the limit (6-7.5k) the the factory setup is worth looking into. It integrates with the electronics of the car and adjusts braking and shifting qualities, and even turns off the backup sensors.
(I wish it would allow you to back up with the driver's door open...)
Old Mar 9, 2023 | 08:57 PM
GLS 550
Trailer hitch
I would like for it to compliment an original factory install
Old Mar 13, 2023 | 01:29 PM
SUV John's Avatar
Veteran: Air Force
2016 GLE 350 4Matic, 2019 GLS 450 4Matic
For added hitches such as the one from etrailer.com, be aware that they state the hitch does not allow the use of weight distribution and the hitch does not fit models with the Active Curve system if that's a factor. Also, if you need an electric brake controller, you'd have to find the best place to make the connections. Otherwise, online videos should help with those points.
Call etrailer.com at 1-800-940-8924 for fit info. They've been very helpful anytime I've called them. They also had the pigtail harness for the electric brake controller when I needed one for the GLE 350 I towed with. If you're not prewired, you'll need a female connector for the vehicle side when using an electric brake controller.
