GLS Class (X166) Produced from 2016 to 2019
Air filter replacement GLS 550 2017
Old Jun 23, 2023 | 10:48 AM
Boulz's Avatar
2017 GLS550
Hi, looking to replace my air filters on 2017 GLS 550, got the engine covers off and trying to figure out how to remove the air filter boxes. Don't want to break anything so hoping to get some guidance on this. I can't find any previous threads on this or any YouTube videos for this engine. It appears the air boxes need to be removed and flipped upside down to remove the torx screws to open them up and replace the air filters.
Anyone have a video or instructions on how to do this? Thank you so much!
John in Connecticut
2017 GLS550
Old Jun 23, 2023 | 06:50 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Old Jun 24, 2023 | 09:16 AM
clarkpittman's Avatar
GLS550, GLE450 Coupe
John in Connecticut
2017 GLS550
John, I recently did mine after lamenting the lack of information about it. The filter box on the left (as viewed from the front looking into the engine bay) can be removed. Just one electrical clip IIRC. Now, the one on the right (the driver's side) is a different beast. I finally realized that the trick is to NOT REMOVE IT! Once the air duct is disconnected from the front, you can gently tip (or twist) it toward the passenger side enough to get the screws loose without having to disconnect that one problem hose. The side of the filter canister that is closest to the driver's side front tire will go counterclockwise about 45 to 60 degrees which will be enough to loosen the screws!
It is a bit of a challenge but if you've turned wrenches before you'll be fine. This is one of those times that being slow, methodical, and patient will serve you well.
I didn't think it was possible and I was ready to cut that compression band off that one hose but it works. It is a very satisfying task if you take your time and just look closely.
I'm giving you permission to crack a nice, cold, frothy brewski when you're done. Cheers!
Old Nov 1, 2023 | 12:01 AM
Stevieboy1's Avatar
2013 SL550 Edition 1 and 2017 GLS 550
Hi Clarkpitman,
Posting this way late!
I had the same exact experience you did. It was a real pain to get the right box unhooked. I was ready to cut or break the clip and it drove me nuts before I finally figured. It out. You can’t see back there to the clip so it’s very frustrating. Once you know how to do it, it’s straightforward, but still a pain!!
