GLS Class (X166) Produced from 2016 to 2019
GLS63 2017 Suspension issue.
Old Jul 1, 2024 | 09:21 PM
Mamba003's Avatar
2005 E55
Today I was setting up to do the rear brake pads. To do so it says to raise the truck via the suspension button on the center dash. I did that and everything seemed fine and then all of a sudden I heard a loud PSSHHHHH! Like a truck with air brakes just pulled up.
obviously something went wrong. Weird part, no codes, check engine light etc. it is sitting weird, particular low at passenger rear and high on driver front. I drove it hoping it would settle but didn’t. Also when driving it didn’t seem like a corner lost an airbag.
As I was fiddling with the suspension raise button I would get a message on the dash that said “compressor cooling”. I suppose that’s the air compressor for the suspension. Is that the problem?
Old Jul 2, 2024 | 08:30 AM
clarkpittman's Avatar
GLS550, GLE450 Coupe
Sounds like you lost the passenger / rear air bag. Do a search on this forum for the preferred replacement parts if you're DIY. There seem to be two brands that most like: Corteco and Arnott. Some have said that the Corteco brand is Mercedes' OE
Old Jul 2, 2024 | 09:37 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
That's probably from trying to inflate a bag with a hole in it...
Old Jul 2, 2024 | 10:24 AM
wildta's Avatar
GLE 580
Yes and I would be careful about the compressor going caput too.
