GLS Class (X166) Produced from 2016 to 2019
2020 MB GLS450 Transmission or Brakes?
Old Sep 5, 2024 | 09:54 PM
mose61's Avatar
I'm looking at buying this GLS and took a test drive and heard a grinding, almost clicking sound when slowing down and braking. The car has about 59,000 miles on it.
After driving the car for 10-15 minutes the sound went away. Have anyone had a similar thing happen? If so, what was the issue and fix/repair?
Would you buy it?
Thanks so much
- Mose
Old Sep 6, 2024 | 07:11 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Clicking is going to be suspension ball joint, tie rod ends, CV axle, sway bar links. It's the sound of a joint buckling under load/deload. Cars too new to really have these issues although the way I drive, I cook sway bar links every couple years. The repair is like $600. Grinding? Do you have pictures of the brake rotors so I can rule out warped rotors?
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Sep 6, 2024 | 07:31 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Posting in the correct section may yield more responses. GLS Class (X167) - MBWorld.org Forums
