GLS Class (X166) Produced from 2016 to 2019
Should I keep the GLS?
Old Sep 16, 2024 | 02:48 AM
gls_lover's Avatar
GLS550
Question Should I keep the GLS?
I have a 2017 GLS 550 with about 127K miles on it. I've keep the maintenance up to date with oil changes every 7-9k miles, replaced spark plugs and radiator at 110k. I was recommended the following items which will approximately cost around 8k.
1. Upper Timing Cover Reseal
2. Remove & Replace Drive Belt and Idler Pulley
3. Remove & Replace Water Pump and Turbo Coolant
4. Remove & Replace Suspension Control Arm Bushings
5. Probably would need to replace brakes soon
My thoughts:
1. I would love to keep it. It's an amazing car.
2. Is it worth putting money in to get everything fixed? My concern are other issues that might come up after this.
3. Does anyone have a high mileage GLS 550 and what are your recommendations.
Old Sep 16, 2024 | 09:38 AM
jimyj's Avatar
E320
Hey gls_lover, I understand the dilemma you're facing with your GLS 550. At 127K miles, it's normal for some major components to start needing attention, especially if you've been diligent with maintenance. Investing in those repairs could extend the life of your vehicle, but there's always the risk that other issues might emerge down the road. I've seen high-mileage GLS models hold up well with timely maintenance, but it's a bit of a gamble whether it's worth the current investment versus putting that money towards a newer vehicle.
Old Sep 16, 2024 | 10:25 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
My thoughts:
Is the timing cover leaking? If not, I wouldn't bother. The rest of the list is good preventative maintenance as are the engine mounts. I would get a quote from an independent and use the difference to buy an Alaskan cruise.
Old Sep 16, 2024 | 12:29 PM
FWP!'s Avatar
2017 GLS 550
From what I've heard, the turbos will need to be replaced soon at that mileage. And it's a big job, apparently the motor has to get pulled.
Old Sep 16, 2024 | 02:45 PM
Boraxo's Avatar
GLS450
Ask your mechanic which items are the highest priority and go from there. Often you can defer some of the less critical items. Keep in mind Benz service advisor have no conception of price or budgeting and will just send you a laundry list as they are compensated on what they sell. A good indy mechanic can advise on what items are urgent.
$8k at once is a lot, but $4k a year not so much for German cars at this mileage. Keep in mind a new vehicle will cost you $100k. I have yet to see any critical new safety or luxury features that would require me to upgrade. Would love to have appleplay but the bluetooth works just fine.
Yes we got a fault code for turbos (110k mi) but they seem to be doing ok.
Old Oct 11, 2024 | 01:45 PM
mrobinso's Avatar
2021 Yukon XL Denali, 2017 GLS450 4MATIC, 1993 Chevy Corvette
I agree with this sentiment. You probably don't need any of those except from personal experience the serpentine belt and pulley should be done at this mileage if you haven't ever serviced those. You can wait on the others, but the water pump and turbo coolant may be needed, I'm less familiar with the service interval. The bushings (will improve ride) are not required, timing cover (unless leaking) is not required.
The GLS550 still holds up relative to a lot of newer models, and the value you'll get on trade/selling it won't be much. IMO the new GLS is not really worth the significant price premium as it is a very similar car with new sheet metal, unless money is not really a factor.
Old Nov 12, 2024 | 08:08 PM
PedsDocMD's Avatar
GLC 300
Love this reasoning. Did you know you can purchase an Apple play kit and install it? Have to take dash apart but looks super cool.
Old Dec 12, 2024 | 03:18 PM
bkdc's Avatar
2015 S550, 2017 GLS450
I am in a similar situation. 2017 GLS450 with 110K miles, meticulous maintenance. No leaks after I fixed the usual left front timing cover leak. I’ve already done the belt/idler pulley. I’ve already changed the coolant twice during ownership. This is an often forgotten maintenance issue as the coolant loses its anticorrosive activities with time and can lead to earlier water pump failure and other leaks.
Thinking about pending airmatic issues, suspension refresh, turbo issues and two routine maintenance issues upcoming (spark plugs/ignition coils and tranny filter change/service/rear differential oil change). I switched to oil changes at 5K intervals at home knowing that this will delay turbo failure. I’m inclined to perform a full suspension refresh and at least make this car drive like new and hope I get a few more years out of it as it will be more economical than buying a new car unless the new car is a Toyota.
Old Dec 12, 2024 | 06:11 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
1) if the cover isn't leaking, leave it. If it is a minor, dust collecting type of leak, leave it. If it actually leaves a puddle in the belly pan, fix it.
2) basic maintenance and easy (enough) to do in the driveway. Is the belt cracked or sloughing bits? Yes: do it. No, and the bearings aren't loud when the engine is cold, don't bother.
3) drain and fill coolant? Easy and worth doing before 150K miles.
4) Is the steering still tight or do you feel slop? If the former, skip it. If the latter, do it.
5) Brakes are easy; what do the pads and rotors look like? If there's only a few mm left on the pads, it's time.
I'm struggling to see how this list could be over 4k to say nothing of $8K.
