GLS Class (X166) Produced from 2016 to 2019
Turn Signal Error Message
Old Jan 7, 2025 | 12:59 PM
Kbach's Avatar
GLS550
I replaced a damaged left rear turn signal with an aftermarket one off eBay. The fit and finish was great, but it gives a check left rear turn signal warning and fast flash. The auto shop I had check to see if they could adjust the computer said they would need to replace the turn signal with an OEM unit. When I asked about installing a load resistor, they said they do not do modifications like that.
My question is, has anyone else had this issue and will a 50w 6 ohm resistor resolve the problem. I think I'd just need to identify the correct wires on the plug to install.
Any thoughts...
Old Jan 7, 2025 | 04:11 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
What kind of bulb was in the original? What's in the replacement? Does the vendor you got it from have a suggestion?
Old Jan 7, 2025 | 06:54 PM
Kbach's Avatar
GLS550
The tail lights do not actually have individual bulbs. It’s a complete unit with individual LEDs that gets changed out.
I contacted the vendor and they recommended taking it the a shop and adjust the computer. I got it off eBay and it’s more than likely Chinese.
Old Jan 7, 2025 | 08:40 PM
John CC's Avatar
Well, the load resistor for sure won't work.
Old Jan 24, 2025 | 07:26 PM
Kbach's Avatar
GLS550
I took the vehicle to a shop and they couldn’t do anything to clear the error code. Ended up getting a refund and buying a used OEM taillight.
