GLS Class (X166) Produced from 2016 to 2019
low coolant level
Old Feb 10, 2025 | 03:55 PM
nioero's Avatar
low coolant level
2017 gls550 with 120K km..
so I have some heat related issue and an indy shop replaced the water pump and a few coolant lines. the heat seems to be improving but I had a coolant low level after driving 150km or so.
topped up the coolant and it was low again. based on my estimate, i have to top up 800mL of coolant for every 150 km driven. it seems that the coolant is "disappearing" at a rate of 6ml/km driven.
brought the car back to the shop and they found a leak on one of the pressure relief lines after the pressure test. the line was replaced however the symptom persists.
I brought the car back again today and they performed pressure test again without finding any issues..
i do find small drips of pink coolant on the floor sometimes but it is not consistent.
engine oil looks clean so they don't think it is head gasket.
just to add that since the water pump was replaced, i drove about 700kms and i topped up about 3L of coolant mix..
what else can be the issue? anything that the pressure leak test won't detect?
Old Feb 10, 2025 | 05:18 PM
chassis's Avatar
2017 GLE350 4MATIC
Reservoir leak
hose leak
oil cooler leak
transmission cooler leak
radiator leak
You need to see exactly what is leaking. This requires an hour of careful inspection with a bright LED flashlight.
Old Feb 10, 2025 | 05:23 PM
nioero's Avatar
Originally Posted by chassis
Reservoir leak
hose leak
oil cooler leak
radiator leak
Like i mentioned, the indy shop probably have spent 3-4 hours on it and couldn’t identify issues.
they told me that the coolant system holds pressure.
Old Feb 10, 2025 | 05:25 PM
chassis's Avatar
2017 GLE350 4MATIC
OK. What is the next step?
Old Feb 10, 2025 | 05:35 PM
nioero's Avatar
not sure.
i will give another shop a try.
Old Feb 11, 2025 | 08:13 AM
BobSandra's Avatar
550GLS
Head gasket...
Old Feb 11, 2025 | 09:25 AM
W205C43PFL's Avatar
Originally Posted by BobSandra
Head gasket...
Ouch that can't be good : (
Old Feb 11, 2025 | 09:52 AM
nioero's Avatar
Head gasket...
the oil was checked and i dont see any milky stuff. Also there is no unusual amount of white smoke other than what can be seen in a typical winter. I just found it odd that this happens after the indy shop replaced the water pump and a few coolant lines.
my b1 service is due in a few weeks and i will bring the car to another reputable shop in my area to do the service and will see if they can found anything.
Old Feb 11, 2025 | 10:41 AM
BobSandra's Avatar
550GLS
A bad HG does not always show as milky oil. It depends on where the failure occurs. It may be a very small 'leak' that's exiting thru the exhaust and is barely visible.
Old Feb 11, 2025 | 10:44 AM
nioero's Avatar
ok.
what do you think of the loss rate of 800 ml per 130kms. To me it seems pretty high.
Old Feb 11, 2025 | 11:43 AM
BobSandra's Avatar
550GLS
2.7 oz in 80 miles. Is not a lot.
Old Feb 11, 2025 | 11:58 AM
nioero's Avatar
i think you missed a digit. It is actually 27 oz. I would just live with 2.7 oz.
Old Feb 11, 2025 | 09:26 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Check the radiator hoses an hour or two after driving the car. If the head gasket is leaking to the cooling system the hose will likely be rock hard. Also, 27 oz in 80 miles, or 800 ml in 130 km, or a quart in 100 miles, all would make a lot of smoke.
Old Feb 12, 2025 | 06:39 AM
nioero's Avatar
that is what the mechanic told me as well. It would be smoke galore lol
Old Feb 12, 2025 | 09:33 AM
W205C43PFL's Avatar
Phew then it is not a head gasket.
Old Feb 12, 2025 | 10:39 AM
nioero's Avatar
I found it too coincidental that it got worse after the water pump was replaced. I did have to top up coolant once or twice a year since 80k km but it was nothing like now.
maybe the old pump was faulty and the new one made the leak worse since it pumps better now?
Old Feb 12, 2025 | 11:21 AM
John CC's Avatar
Does your water pump have a vacuum line connected to it? My GLK has a vacuum line that actually closes off the water pump when the engine is cold. It makes the engine warm up quickly, but the mechanism can leak, allowing the vacuum system to be contaminated with coolant, and causing a slow loss of coolant. Nothing like 800 ml in 130 km, though.
Old Feb 12, 2025 | 11:32 AM
nioero's Avatar
I dont know if it has one or not. I dont see any lines and based on what I researched nobody has mentioned the line yet.
the indy shop did replace 4 hoses while they were at it. I was told those lines are brittle though i have no idea what they are except for generic terms like “ coolant line” or “ coolant return line”.
Old Feb 20, 2025 | 08:20 AM
nioero's Avatar
just an update: after the 3rd visit to the indy ( i was told that they didnt do anything except verifying that everything’s okay) i drove maybe another 160km or 100 miles i was expecting to fill up another 20oz or so. But to my surprise, the coolant level didn’t drop at all this time!
so since the water pump replacement, i topped up maybe 80-100oz or so coolant and all of a sudden it stopped disappearing. Could it be all air pocket? I found it hard to believe.
Old Mar 29, 2025 | 10:58 AM
nioero's Avatar
another update on this. So I drove another 670 miles but had to top up 29 oz or so coolant. Definitely better than before but still have to top it up every fill-up of gas.
i guess it is kind of acceptable. Based on how much i drive i might have to consume a standard merc jug of coolant a year.
Old Mar 29, 2025 | 11:24 AM
chassis's Avatar
2017 GLE350 4MATIC
Please list all of the tests all mechanics, and you, did to diagnose the coolant leak. Excluding inspection and topping up.
Old Mar 29, 2025 | 11:43 AM
nioero's Avatar
original indy shop did the water pump replacement and performed several pressure tests to the system. One pressure relieve line was replaced since they found bubbles during the pressure test but i dont think it is the issue.
when i did my b1 service at another indy shop a couple of weeks ago they didn’t notice anything but did notice that water pump and a few coolant lines are new ( i didn’t tell them water pump was recently replaced)
i also replaced the coolant reservoir cap myself a couple of weeks ago.
i didnlt notice leaks on the floor or anything this time.
i think that is about it. The car did start to require coolant top ups since maybe 2022 but less often for sure.
Old Mar 29, 2025 | 12:30 PM
John CC's Avatar
Unless there is a known issue, like a vacuum controlled water pump, I'd probably test the coolant for combustion byproducts.
Does the cooling system stay pressurized after it cools down? Does the exhaust have a "sweet" smell, or excess water vapor or white smoke?
Old Mar 29, 2025 | 12:35 PM
nioero's Avatar
no white smoke or smell.
When it first started right after water pump replacement it was missing 10x rate of now, the shop basically told me it would be white smoke galore jf the coolant is leaking through the head gasket and it wasn’t the case.
i think the shop did something when i visited them the last time since it is disappearing at a much slower rate now. They just kept telling me everything is fine and they couldn’t find anything.
Old Mar 29, 2025 | 01:29 PM
John CC's Avatar
Did the problem start with the water pump replacement, or was the water pump replacement an attempt to fix the problem?
How about pressure? Does it dissipate when the system cools?
