GLS Class (X166) Produced from 2016 to 2019
2017 GLS 450 (X166) - DTC B25B615 EASY-ENTRY System - Diagnostic Help Needed
Old Mar 19, 2025 | 01:30 PM
MS_RIC's Avatar
2017 Mercedes Benz GLS450
Question 2017 GLS 450 (X166) - DTC B25B615 EASY-ENTRY System - Diagnostic Help Needed
Hi fellow DIYers,
Need guidance on diagnosing a persistent DTC in my 2017 GLS 450 (X166). After replacing both batteries, cleared all codes except the one below:
  • Code: B25B615
  • Description: Switch "EASY-ENTRY system" in the right seat has a malfunction. Short circuit to positive or open circuit.
  • Status: Stored and Current
Looking for:
  1. Location of the switch/wiring harness for right seat EASY-ENTRY
  2. Diagnostic steps to isolate switch vs. wiring issue
  3. Experience from anyone who's dealt with this specific code
  4. Known fixes or common failure points
Any help appreciated. Trying to avoid dealer visit if possible.
Old Apr 19, 2025 | 01:58 PM
MS_RIC's Avatar
A quick update - I obtained a Launch Creader Elite 2.0 BBA scanner. Using Actuation Tests, I was able to get into the Rear Control Module where Easy Entry system is located, performed actuation for both left and right sides, and it went fine. However, the DTC is still there (stored and current) and cannot be cleared.
I would appreciate any guidance and help.
