GLS Class (X166) Produced from 2016 to 2019
Front Differential
Old Mar 29, 2025 | 09:48 AM
Pwhitty's Avatar
2009 C63 AMG
Front Differential
Looking good for a little help here. I took the GLS550 to the shop for what I thought was a wheel bearing. After diagnosing the issue they said the noise was coming from my differential and that they do not do this service. The noise is almost like a road whine.
Questions:
Without much further diagnosis, Is it worth changing the fluid to see if the issue resolves itself?
If I do the fluid change, what is the part number for the drain plugs?
Is the fluid change as simple as
Unscrewing the top plug
Unscrewing the bottom plug
Draining and refilling
Old Mar 29, 2025 | 12:17 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
No, it's not whining because the fluid is worn out, but, you might learn something from the fluid you drain out.
Old Mar 29, 2025 | 02:14 PM
chassis's Avatar
2017 GLE350 4MATIC
Questions:
Considering the cost to replace the axle, changing the fluid is easy and low cost, therefore is worth doing as a diagnostic step.
It's an easy procedure.
Remove fill plug
Remove drain plug
Capture old fluid
Install new drain plug, p/n A1643310056, torque 35Nm
Fill new fluid using Motive tool or equivalent
Install new fill plug, p/n A1643310056, torque 35Nm
DIY and WIS: https://mbworld.org/forums/gle-class...ml#post8345443
Old Mar 29, 2025 | 04:03 PM
Pwhitty's Avatar
2009 C63 AMG
yeah, that was was I was thinking but didn't want to come to the conclusion of needing a rebuild or new install. I will call my Indy shop Monday and see when I can get it in or at least get a quote. Any guesses on pricing?
Old Mar 29, 2025 | 04:54 PM
John CC's Avatar
Not really. Sometimes all you need is a few bearings. To replace the whole thing, in Mercedes Bucks, I can only imagine.
Old Apr 20, 2025 | 10:25 PM
20C4S's Avatar
How many miles on the car? can you describe more on the road whine in detail?
Old Apr 20, 2025 | 11:27 PM
Pwhitty's Avatar
2009 C63 AMG
It almost feels like you are driving on a rough road with road noise, like a drone sound on the interior. You can also feel it in the pedal.
I did get the car into another shop this past week. I dropped it off at 8am and got a text that they needed me back at the shop at noon. When I came back, the owner/lead tech said he has never seen an issue like this. He said that my front and rear diff's were shot. He had me listen with his stethoscope so that I could hear the grinding. 2 remanufactured diff's with 4yr warranty is going to cost roughly $8500.
I have had the car in the garage trying to figure out next steps. I am half temped to try the replacement myself, but I can't seem to find any good tutorials.
Old Apr 21, 2025 | 07:04 AM
W205C43PFL's Avatar
Yikes... Both are shot.
Old Apr 21, 2025 | 07:05 AM
W205C43PFL's Avatar
Do you tow a lot, original owner? What type of driving do you do? What type of roads are the vehicle driven on? Vehicle gets stuck often?
Old Apr 21, 2025 | 07:06 AM
W205C43PFL's Avatar
Any aggressive driving? 0-60 runs?
Old Apr 21, 2025 | 07:15 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Thing to know....we had a TOTAL service done on ours. After the service the diff rear seal is leaking a drip (here and there, so the story goes). The fix? Easy, the part...under $5.00....the "Special Tool" required to press in the gasket was like $300 and the labor is way outta hand.
Thankfully my shop/mechanic are also friends......the commenters about changing the fluid first? I agree with them 100%. It is a cheap and easy experiment.
Old Apr 21, 2025 | 09:27 AM
Pwhitty's Avatar
2009 C63 AMG
the funny thing is, is that I have 0 leaks. From the exterior, everything looks good.
Old Apr 21, 2025 | 09:56 AM
I had zero leaks before the service......
Old Apr 21, 2025 | 11:23 AM
Pwhitty's Avatar
2009 C63 AMG
Nope, not by me at least. Indid pick up the vehicle with 72k on the odometer though.
Old Apr 21, 2025 | 11:48 AM
Pwhitty's Avatar
2009 C63 AMG
Old Apr 21, 2025 | 12:09 PM
W205C43PFL's Avatar
I see so used vehicle, will not know what the vehicle been through prior to you buying it.
Old Apr 21, 2025 | 03:21 PM
Pwhitty's Avatar
2009 C63 AMG
yep. The carfax came back good and had a good history of service over the years. That and it appeared to be pretty well maintained.
Old Apr 21, 2025 | 03:41 PM
W205C43PFL's Avatar
Carfax won't tell you the previous driver's driving style and how much they tow.
Old Apr 21, 2025 | 03:58 PM
Pwhitty's Avatar
2009 C63 AMG
I agree 100%.
Old Apr 21, 2025 | 04:35 PM
W205C43PFL's Avatar
I agree 100%.
Either way, hope things work out for you OP, it is otherwise a great vehicle.
