Hardwiring Radar/Dash cam?
There's also a fuse box under the passenger side glove box, but requires taking out a few components in there to access that. If you want a rear camera I recommend you just run the wire back. To do this you can either go through the roof lining or the foot well. Either way you should take off the A pillar to run the cable behind the airbag so it does not get interfered.
It's easy enough to run the cable under the trunk lining from the fuse box to the wheel wheel if you have the external battery too.
Why did you decide to tap the fuse box in the rear instead of the fuse box behind the glove box? Was it because you had a backup battery? I do not have a backup battery so intend to just use the front passenger fuse box. Is it difficult to access? Thanks.
1. I had a rear camera that I had to run a line to the tail gate anyways, so I just ran both lines back and it was easier.
2. The tail gate fuse box is much easier to access than the glove fuse box. I wasn't a fan of bending down under the glove box and taking things apart there when I can just access the rear fuse box directly with a twist of a knob.
If you have only a front dash cam, you don't really need to go to the back if you know how to run the wire into the glove box. It might not be worth the hassle though with the number of parts you have to take apart to access it. I feel its easier to just run the wire to the back, just make sure your wire is long enough.
One thing to make sure is that your wires are long enough for the GLS.
