GLS Class (X167) Produced 2020 to present
GLS 580 tune
Old Jan 24, 2021 | 12:16 PM
omega910's Avatar
audi sq7
GLS 580 tune
I am torn between the 63 or the 580. Has anyone tuned the 580? Is so how is the performance? Is the tune available from the dealer or ca it be hidden in sport or sport+ to avoid detection?
thanks
Old Jan 24, 2021 | 07:58 PM
335X-ray's Avatar
2021 GLS63
thanks
There are no tunes that I know of for the 580 (or 63) right now probably because of the EQ Boost.
X
Old Jan 25, 2021 | 03:23 AM
Pachole's Avatar
E220d T
thanks
Brabus have a tune!
https://www.brabus-bobforstner.com/c...0-550-gls-580/
Old Jan 25, 2021 | 08:08 AM
335X-ray's Avatar
2021 GLS63
Originally Posted by Pachole
You are right but it is an auxiliary box not a true ECU tune. It probably modifies the input the ECU sees to make the ECU adjust. I would much rather have a true ECU tune when someone cracks the ECU and you can tune without an extra box or having your ECU physically cracked open (Weistech).
X
Old Jan 26, 2021 | 02:53 PM
nicolas2807vn's Avatar
gls 450
thanks
here bro , i was tunned up to 63 with 580 !
https://mbworld.org/forums/gls-class...-amg-part.html
Old Jan 26, 2021 | 03:23 PM
jomama's Avatar
2021 GLS450
thanks
if the GLS 580 shares an engine with the C63/E63/GTS/GLC63, which i believe it does, a "piggyback" is available from burger tuning - https://burgertuning.com/collections...mg_c63_e63_jb4. fwiw, their solutions are a bit more sophisticated than a conventional piggyback as they monitor quite a few signals and adjust accordingly. they also start mild and then create more aggressive maps based on your datalogging. if you're not familiar, they have some of the fastest turbo applications across a number of different platforms (different makes and models). if i were to bet, a 580 with the JB4 will produce more power than the 63. it'll also allow you to play around with the fuel if you want to (e85 mix, methanol injection, race fuel, etc.).
when my gls 450 arrives, i'm going to ping them about producing a solution for the m256 inline 6 turbo engine, which is a relatively new deviation from the v6 turbo engine that is found in the GLC53 and other earlier 450 cars.
Old Jan 26, 2021 | 03:56 PM
gls 450
bro , new eq boost engine of x167 i think has a lot different with the old one , they blended conventional mechanical operation + AL, which means we can intervene in the IC system to tune it easily, if you want to upgrade a new Mercedes with MBUX, what you should do is find a good coding engineer. Brabus has always wanted to outperform AMG, so Daimler has tweaked their sales mindset so that you can tweak the options on your car like an upgraded steering wheel, amg drive unit or even an upgraded. online on your phone via Mercedes Me, which is completely absent in older versions! In the new car, the turbo seems to be workless with the EQ boost, it's just a circuit and coding but it can significantly increase compared to a normal Turbo and absolutely no delay. For me the 450 is more than enough with a V6 if you don't need for a long race. And believe me if you are preparing for a full upgrade with genuine spare parts, it might just be a bit more expensive with the tunning out there, but definitely a good option compared to the real 63!
Old Jan 26, 2021 | 03:59 PM
places's Avatar
No more MB:(
Just get a 63. Why go through all that?
Old Jan 29, 2021 | 12:56 PM
mikapen's Avatar
There are plenty of reasons to prefer the 580 over a 63. I suppose that's why the OP posed the question.
Old Jun 23, 2022 | 08:49 PM
TTJL00's Avatar
2021 GLS580 Renntech ECU
Renntech ECU upgrade
thanks
I went with a Renntech ECU upgrade which does not void warranty if installed by a Mercedes Renntech Authorized dealer. Aristocrat Motors close to Kansas City, MO is where I went. Renntech Dyno puts the 580 at 598hp and 705 lbs of torque. It is a speed bus now and the trailer with RZRs loaded up is a breeze to pull. Crazy power and defies logic now.
Old Feb 14, 2023 | 11:47 PM
wildta's Avatar
GLE 580
How are your MPGs?
Old Feb 15, 2023 | 07:39 AM
TTJL00's Avatar
Originally Posted by wildta
How are your MPGs?
20ish HWY, really not much change there. When I drive, less because my foot is in it so much. The power is addictive. Pulling RZR on trailer across Kansas in the wind driving 80-85mph it was a dismal 7-9mpg. Drop down to 65-70mph and that improved to 12mpg. Without the trailer MPG holds to the 19+ range in Economy.
Old Feb 15, 2023 | 09:52 AM
madkow70's Avatar
'20 GLS580, '18 S560
Renntech also has Handheld OBD tuning module (HHT) available too X167 580 now.
Old Feb 15, 2023 | 05:16 PM
Trimmer2's Avatar
Looks like a new CPC Module upgrade now too:
https://www.renntechmercedes.com/ind...ech-cpc-detail
Available on both the 63 and 580 with ECU rune
Old Jan 30, 2025 | 10:27 AM
arnask's Avatar
GLS 580
Any news on tuning 580 over past couple years?
Old Jan 30, 2025 | 10:38 AM
mikapen's Avatar
I wonder if the Brabus 800 would work on a 580.
Old Jan 30, 2025 | 10:45 AM
arnask's Avatar
GLS 580
Mansory is also selling one: https://www.mansory.com/car/mercedes-benz-gls
Old Mar 14, 2025 | 01:55 AM
zimirza2003's Avatar
!90 E 1984, 300D 1984, 300SD 1986, 300TD 1988, 400SE 1990, 500CL 1995, GL350 2012, GLS580 2020, 2025
I bought my first Mercedes in 1984 since then I owned 8 different models, the last two are 2020 GL580 and 2025GLS580
I tow my Airstream trailer with them without any problem.
Some of the characteristics I like are power, handling, comfort and safety features.
The is my personal experience and opinion and I may be wrong
Cheers
Old Sep 6, 2025 | 12:10 AM
bully63's Avatar
GLS580 GLE63S GT53
Whats the 0 to 60 with the rennetch on the gls580
What is the 0 to 60 with the renntech upgrade on the 580? Ive been looking to purchase but aabtes a little more info thanks
