GLS Class (X167) Produced 2020 to present
Adjustable suspension height - help me understand
Old Jul 8, 2022 | 01:27 PM
BR_Dub's Avatar
gls-450
I am looking at a 2020 GLS-450 with the standard suspension, not the upgraded one. No off-road package either. My question is around the maximum suspension height available: it looks like you can adjust it all the way up to 3.5" above normal. Can you drive like that? I see that it's the maximum height when in car-wash mode, so what does that mean? Can you drive in car-wash mode?
Okay second question: IMHO running boards make any SUV look weak. Can you remove running boards from a GLS without glaring holes?
Old Jul 8, 2022 | 02:07 PM
kosta15auto's Avatar
2022 GLS 450 (X167)
You can't drive in carwash mode. You can't ride in off-road mode all the time. You can't ride at max height all the time either.
As soon as you go over a certain speed the car will drop down to a lower or normal height.
You can't drive it jacked up all the time. It looks cool though besides the fact I usually drive from the inside most of the time and can't see it anyway.
Old Jul 8, 2022 | 02:09 PM
BR_Dub's Avatar
gls-450
Thanks Kosta15auto. But can you drive at low speeds over a bumpy road with the suspension set high? Any idea what the max speed is at that height before the computers take over??
Old Jul 8, 2022 | 02:17 PM
2022 GLS 450 (X167)
I don't recall the max speed for off-road height or max height. It is like 35mph. It is in the manual I remember. It is not time-based or distance but only speed based. Check it out, set it up at max height and go drive normal. In off-road mode, it is holding into first gear longer which makes sense if you're trying to navigate through challenging terrain.
Old Jul 9, 2022 | 01:24 PM
mercedesmax's Avatar
2015 CLS 550 2015 ML 400 Previous 2020 GLB 250 2019 A 220 2005 ML 350 1989 300 E 2001 SL 500
I believe its about 25mph.
Old Sep 11, 2022 | 03:20 AM
Benzworktruck's Avatar
X167
you can drive in car wash mode 3.5'' lift but not very fast. Im hoping to find someone who can unlock offroad + mode wich lifts the GLS to the max 3.5'' hieght just like car wash mode
because it would be useful to have the extra inch of clearnce when off-roading
Old Sep 11, 2022 | 02:56 PM
darlop's Avatar
a
If you want the full ride height you get the off road package or get coding done.
Old Sep 11, 2022 | 07:16 PM
X167
Who can do the coding because i DEF want offroad +
