2017 GLS450 2nd row seat backrest stuck in folded position.
Hi everyone, I’m new to this forum, apologies if this issue has been discussed before.
The driver side 2nd row seat backrest stuck in a folded position and can’t get it upright, tried to troubleshoot here are the points that I’ve found so far:
1-both sides of the seat latches to the car floor (so no issue here)
2-emergency release not unlocking one of the latches (not the door side, the other side). the wire/cable that gets to the latch has slight tension but not enough to unlock.
3-instead when getting the backrest upright once it gets 45 degree the same latch above gets unlocked through the cable( not sure this is normal and part of mechanism)
i tried to manually lock the latches with my fingers and disable the cable so it doesn’t unlock (as described #3). still the seat get stuck at 45 degree when I pull it
anyone has experienced a similar issue?
appreciate anything you can offer
@EWL5 Are you sure it was the fuse, because brining the backseat upright its a manual process not an electric function. Just snapping the base and pulling the backrest up.
Thank you for your quick reply
Yes, try to disassemble the left panel that the seat lever is located (find two screws). My issue was the wire that acts as connector to the latches was loose was put in place, it worked.
Good Luck
Good Luck
