GLS Class (X167) Produced 2020 to present
ILS Intelligent Lighting - 2023 GLS 450 - alignment? review - specs?
Old Dec 25, 2023 | 09:57 AM
wildta's Avatar
GLE 580
Originally Posted by EleBest
ILS+ is actually called IHC+ in these new car models, SA628 is the option code.
For most ECE cars, it is available if your light is Multibeam version (SA642 or SA641).
For USA, there is only SA640, and SA608(IHC, High Beam Assist).
so if you want to know whether your car can be coded the ILS+ or IHC+, basically check you have code 640 and 608, if yes, then can do coding to turn 628 on.
if you have 631/632 and 608, then no way to code 628, as the light hardware has not such feature.
For digital light: if your car has code 316+608, then can do ILS+ / IHC+.
cheers!
Thank you Elebest. For US cars with code 640, can you clarify these items will be activated or not with your programming and which of these are already activated in the US?
​​​​From the UK manual pages 153-157:
  1. Active headlamps
  2. Cornering light
  3. Roundabout and junction function
  4. Highway or motorway mode
  5. Off-road Lighting
  6. Enhanced fog light function
  7. Bad weather light
  8. City lighting
  9. Adaptive highbeam assist
  10. Adaptive highbeam assist plus
Old Dec 26, 2023 | 05:13 AM
EleBest's Avatar
SPONSOR
E200 2010, G63 2018, E53s 2019, EQS53 Touring 2021, S500 2022, A200 2023
  1. Active headlamps
  2. Cornering light
  8. City lighting
I believe all will be working, unless the headlights has some hardware differences. I did not get chance to test all of them in USA road, but from my customer feedback, no complaints so far.
Old Dec 26, 2023 | 09:55 AM
w220430's Avatar
2024 GLS 580. Formerly 2015 GL 550, 2003 S430.
This is indeed very interesting, but what are the implications of coding when it comes to the factory warranty on the vehicle?
Old Jan 1, 2024 | 09:11 PM
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
Everyone who got this done, can you please link the coding device you bought? I was told openport 2.0 but am unsure of which to buy for our gls580. TIA
Old Jan 2, 2024 | 01:10 PM
clunker's Avatar
X167 GLS450 W113 280SL W463.227 300GE
used RJ Automotive - as have others - very happy with their service
see this thread
https://mbworld.org/forums/gls-class...ml#post8553062
Old Jan 2, 2024 | 03:04 PM
wildta's Avatar
GLE 580
see this thread
I did as well but I am certain my cornering lights while turning/curves are not activated. Are yours?
Old Jan 2, 2024 | 03:15 PM
  #32
clunker's Avatar
fair concern and good diligence - yes all cornering lights and previous functionality remains and works, all updates by RJ Automotive were additive to exiting functionality. tbh its a no brainer - without it you have multi thousand dollar headlights configured like a mazda (which has cornering lights - and i like mazdas btw).
Old Jan 2, 2024 | 09:37 PM
  #33
wildta's Avatar
GLE 580
Sorry just to clarify, you can see your lights follow curves as you turn? My RJ programming does not so maybe I need to contact him. He also said he doesn't do the increased brightness for US because they might flicker but he said he'll do it for me and see. This is a learning experience for me and possibly for others that not all ILS programming is the same. Just an FYI for everyone reading about this until I get it figured out further. At least the most important aspect is programmed which is the partial highbeam assist to not dazzle specific cars in front of you. But I want the best or nothing so if RJ might not be providing the full suite then who is?
Old Sep 27, 2025 | 11:03 PM
  #34
Savannah_GLS450's Avatar
GLS450
There seems to be a lot of technical people in this thread so I thought I'd post a question, in these X167 multi beams where is the coding actually stored in the unit? Is it in the headlight housing or one of the 2 modules screwed to the outside? Could one swap a new housing to the SUV and keep the original modules without coding?
Old Sep 27, 2025 | 11:49 PM
  #35
EleBest's Avatar
SPONSOR
Yes. Light housing can swap, without coding. But some need do calibration work, and some used lights might be plug and play. If you need coding, we can try to help.
Old Sep 28, 2025 | 12:04 AM
  #36
GLS450
Thanks for the info. I just did a housing swap and it's all working but one light. I'll have to post a pic. What is this light called? And why would just one not work? Defective housing or coding issue? The other passenger side is working. I know my scanner has options for testing the headlight maybe I'll have more info tomorrow. I need to figure out the cause so I can let the seller know if I need to return it, (which I hope I don't have to)
Old Sep 28, 2025 | 12:15 AM
  #37
EleBest's Avatar
SPONSOR
High chance the light housing hardware issue.
