GLS Class (X167) Produced 2020 to present
New To Me 2021 GLS63 Stability Question
Old Jan 8, 2024 | 10:27 AM
carlosamg50's Avatar
AMG GLS63
Hi guys
Just picked up a 2021 GLS63, tyres are very good, brakes look fine etc. but it tramlines a little when crossing the lane lines on the road and also seems to a little out of control when braking harder when giving it a bit, as if it cant handle its mass and wants to get out of shape, anyone else experience this? I think I have my tyre pressures a little off, with 34 all round, would that be a factor with the symptoms I describe, it doesn't feel out of sorts cruising at motorway speeds, no shimmy when braking etc.
Car is fitted with factory 22's and Conti Sport 6 tyres.
Carl
Old Jan 8, 2024 | 12:42 PM
mikapen's Avatar
My first thought was tire pressure.
A bit of tramlining is to be expected with wide tires, but I'd be concerned about your braking experience.
Start with your gas flap tire pressures to see if that helps. Good luck.
Old Jan 9, 2024 | 08:21 AM
AMG GLS63
Gas cap pressures seem low given the vehicle size, power, wheel size etc. something like 32 front and 31 rear, and other threads on the forum suggest running a bit higher than gas cap.
Thanks for the reply, will make some adjustments and see how it feels.
Old Jan 9, 2024 | 12:24 PM
mike7513's Avatar
22 GLS 450 19 CLS 450
It's because you are driving a massive, powerful vehicle on summer tires or tyres in the winter in the UK. What you are experiencing is your car telling you to give it some winter tires.
My GLS 450 with the 23's behaves the same way in Michigan right now. In the states we would describe it as "squirly". It's your/our tires.
Old Jan 9, 2024 | 02:13 PM
AMG GLS63
Never even thought about the summer tyres in winter, it’s cool here rather than freezing but I guess a few degrees above zero is too cold for the high performance tyres.
Thanks for the response
Old Jan 9, 2024 | 02:19 PM
mike7513's Avatar
My pleasure.
I'm not going to embarrass myself by attempting a Celsius conversion but both manufacturers of the tires that will fit the 23' wheels considers about 45 degrees the cutoff for summer tires.
Old Jan 9, 2024 | 02:22 PM
EWL5's Avatar
'23 GLS450
Summer tires become dangerous below 4°C!
Old Jan 9, 2024 | 03:01 PM
AMG GLS63
It’s around 4 here during the day at the moment, will keep the throttle mashing for the warmer temps, thanks guys.
Took it for granted, last couple of cars had M+S tyres fitted and my G Wagon didn’t bat an eye lid on these cold days LOL.
Old Jan 9, 2024 | 05:27 PM
mikapen's Avatar
Then you're not using the Loud Pedal enough....
Old Jan 9, 2024 | 07:23 PM
AKSwift's Avatar
2012 E Cabrio, 2015 GL , 2017 B ED & 2024 GLS
When we lived in the UK, the local tire guy always enjoyed it when I asked him for winter tires. I was his best customer, no one else bothered. I remember that the rear wheels on the Smart Fortwo (2010) were particularly hard to find and, therefore expensive. Or so I thought - 23" tires are in a whole different league.
That said, having learned to drive in Germany, I'd never think about taking summer tires out below 7C. My Swedish neighbor likes to tell me about one of his teenage jobs being to put studs into the tires - I wouldn't go that far...
Old Jan 10, 2024 | 05:26 PM
nc211's Avatar
2020 GLS450 (wife) / 2024 Ford Bronco (mine) / 2014 VW Tiquan (son)
Ours (21's staggered) has always wiggled when going over the marker tape lines on the road. It's the alignment setup which pushes one side against the other (and eats the tread). Keeps it stable at high speeds, but if one side can push the other, it will.
Old Jan 23, 2024 | 03:26 PM
AMG GLS63
So weather temperatures have improved, driving at around 13 degrees today, still feels unstable, like its constantly adjusting itself on road, and the active roll bars are grabby so pulling the car left to right with wind or road undulations, just not a planted ride.
I dropped the tyre pressures to 34 and 33, no difference really, just feels light and unsettled, with a lot more body roll than I thought with the active roll control etc.
It does have Yokohama tyres front and Continental rear rather than Conti all round, both brands and summer and M0 spec, may influence traction a tiny bit but the lack of control and unsettled feeling on motorway driving can’t be down to tyres, right?
Old Jan 23, 2024 | 03:37 PM
mike7513's Avatar
You're still only at the bottom range of the temps for these tires. And as nc211 added you are always going to have that with the staggered setup running over lane markers, repairs that have been made by sealant rather than cold patch, etc, if you continue to run a summer tire even if it's 85 and full sun. And even if you switched to a smaller wheel and an all season tire you are just gonna mitigate it some more, it's never going to go completely away. I had a loaner 450 that had the 21's on it with all season rubber and same thing just not as violent.
Old Jan 23, 2024 | 09:20 PM
wildta's Avatar
GLE 580
It's called tramlining:
https://en.m.wikipedia.org/wiki/Tram...ed%20sidewalls.
