Magic Vision Wipers for 2024 GLS 580
Tonight, I went through a fairly new car wash from a well-known chain here in Florida. Car wash mode was enabled before entering. Everything went great until the very end. Then, a large arm came down with spinning cloths. It seemed like they were to help dry the car after the blow-dry phase. However, as soon as it went over the hood, it violently tangled with the driver's side Magic Vision wiper and tore it to shreds. There was no way to stop it. When I pulled out of the car wash, with numerous cars behind me going through the automated car wash, there was a piece of rubber dangling from the arm up towards the top of my windshield and some other pieces scattered around on top of my moonroof.
I drove around and flagged down the site manager. He said that if I returned with a receipt, he would refund the total cost of the replacement. I told him it wasn't a normal everyday wiper, and he said he understood that. We'll see what he says when he sees the bill...
Tomorrow, it is supposed to rain all day long. I have an important appointment across town at 1pm. If I could go to Walmart/Sam's Club/Costco/etc. this would not be a concern. But as far as I know, only an MB dealer can get the part for me. Is that true?
I saw another thread that said Valeo sold matching Magic Vision wiper blades and that they were the OEM behind MB's Magic Vision system. Do any shops stock those, or is it online ordering only?
What is the part number for the driver's side Magic Vision Wiper for the 2024 GLS 580? I read through the Owner's Manual, and I could not find this information. Is it required to buy a pair, or can I buy the driver's wiper alone?
If I search mbparts.mbusa.com, (and several other sites), I only see wipers that work for the 2020-2023 GLS 580. I don't see any that are approved for the 2024 GLS 580. I've attached a screenshot of my filters. The result set is empty.
I will check with the local dealer tomorrow morning to see if they have any stock. If they do not, which is likely, this could be a bad situation.
How do I keep the wipers from automatically turning on (perhaps due to a light rain) and scratching up the windshield (since there is no rubber and there is currently a plastic piece directly in contact with the windshield)?
Unfortunately, I don't have access to another vehicle at this time. So I need to sort this out tomorrow morning within a few hours...
I only asked how to disable them to drive across town without them coming on. I found via the manual that moving the dial to the last position does disable the rain-sensing feature, and the wipers won't come on no matter what.
They aren't fully blocked "underneath" the hood, but they don't fold up, as they hit the hood part-way.
So the manual for the MY24 GLS says that you should turn the vehicle on and then immediately off, then press the rear wiper fluid button for 3 seconds within 15 seconds of turning off the vehicle to put them into service mode. It doesn't say that you should not have your foot on the brake for this, but I found that on YouTube. Either way, with or without the foot on the brake (and a full engine start or not), pressing and holding the rear wiper fluid button did not cause the front wipers to enter service mode, but it did waste half a tank of wiper fluid.
YouTube also suggests that you turn the wipers on and then turn off the ignition when they are in the UP position, then you can change them. Well, that doesn't work for the MY24 GLS since the wipers seem to be on battery power. So even with the ignition off, they finish their wipe and go to their closed position.
I spoke to a MB attendant in the parking lot, and he knew a trick. It was to run the wipers and then pull the lever to open the hood (in the driver's compartment). This caused the wipers to stop in the up position.
Either the manual seems to be incorrect, or my vehicle has an issue. I'll have to sort that out at my dealer back home in the coming weeks.
We had to get a mechanic to change the wipers since we could not get it out when it was broken. The manual says that there needs to be a click when you rotate the wiper out, then you push the button and extract the wiper from the base. Well, we couldn't rotate the wiper out to click it, because there was no wiper left. Thankfully, a MB mechanic was able to resolve the issue in about 5 minutes.
In any event you were on the right track, while the manual icon looks like the rear wiper button, it's actually the front wiper button. And you don't have to push it all the way to the wash position, just pressing it to the wipe position and holding activated wiper service mode on ours.
I know a family that owns a carwash chain, and this is actually why a lot of carwashes dont have rotating top mitter thingies (thats a technical term lol):
And instead have these long strippy thingies (another insider term):
Because as you learned those spinning top things can do a lot of damage. At least the damage was only your wiper blade and not the paint!
The front wiper button is on the end of the button 1. They refer to it on page 158 with a blue circle with a 1 in it.
The instructions for moving the wiper arms into the replacement position don't refer to the front wiper button 1, instead, they show the rear wiper "Single wipe / washing" icon (a different button 1).
Perhaps my issue was that I was pressing the rear wiper "Single wipe / washing" icon (button 1) all the way down into "washing" position. Maybe there is a way to press it just enough for "Single wipe" while also holding it down for 3 seconds... I'll give it a shot.
Now that Blackberrys are more or less extinct, everyone is using a phone by touchscreen (no lives lost when you mistype). I'd like to see a car operate by touchscreen!
Glad that project is shutdown.
I am not sure who to contact for manual corrections. But I will reach out to my dealer.
In a tunnel carwash with my company car.
As I approached that spinning brush, I could see that it had adroitly removed an antenna from a preceding car, and it was flailing away, menacingly welcoming me.
I honked and honked, hoping that an attendant would stop the line, unable to brake because of a following car, one slot behind.
Yes, as I went through, it went Screech Screech Screech, and I was glad that it was not my car.
Damage.
End of story.
Damage.
End of story.
