Easy Entry/Exit Feature resets!
When you set your seat memories, are you using the same profile all the time?
I think my only solution is to access my profile by opening the passenger door first, selecting the profile, and then resetting the seat/wheel!
I much prefer BMW's solution where the seating/wheel adjusts automatically to the keyfob on the driver's side.
What I do with my wife's car, who is also short and I can't enter the car with her settings - is to have the #3 driver's seat memory set to my position. I open the door and hit #3 - then I can enter and select my profile.
A workaround, but it saves my neck.
Then I had my A1 today and they did a software update. They didn't delete profiles, but something reset and it forced me through the seat configuration wizard again. After putting in my correct height, the seat promptly proceeded to move to its highest and most forward position. I got squeezed like a lemon. Not fun.
No idea what tomorrow will bring.
That was on my official profile with the Mercedes me symbol superimposed on the profile.
I think I made too many assumptions and wrong settings when I was learning the car (incl RTFM), so I just made another profile with another photo, with no Mercedes me icon, that I use now.
I disabled the height setting this time, because I think It kind of pays attention to where you're sitting and sometimes wants to intervene.
(I doubt that that's really the case, because that would sound like a conspiracy, and I hope cars aren't at the level of sophistication to conspire....)
We don't use profiles. I just open the door, press this memory setting 1, Wait until it adjusts and then get in.
When she drives, she opens the door pushes 2 and gets in.
I think OP is talking about the steering wheel lifting up and out of way and driver's seat moving back.
This solution DID NOT WORK! The MBUX system had turned it off by the next morning. The service technicians DON'T KNOW HOW TO FIX EASY ENTRY/EASY EXIT from resetting itself. There are no bragging rights to owning a Mercedes without Mercedes having competent software programmers to fix MBUX problems.
The key fob coded to different profiles is so much convenient even in entry level cars. MBUSA does not seem yo have a solution for this
