GLS Class (X167) Produced 2020 to present
Nappa Leather Care
Old May 1, 2024 | 03:48 PM
kcwjr's Avatar
Veteran: Navy
2026 E450 AT (on order)
Nappa Leather Care
What type of leather treatment product do you use to care for Nappa Leather?
Old May 1, 2024 | 03:54 PM
chassis's Avatar
2017 GLE350 4MATIC
Cotton terry cloth dampened with plain tap water. Modern automotive leather is polymer coated and impervious to liquids including cleaning products.
Old May 1, 2024 | 05:07 PM
kcwjr's Avatar
Veteran: Navy
Thank you.
Old May 2, 2024 | 05:08 AM
ygmn's Avatar
2015 E400 Sedan
to test for this...
dip fingers in cup of water and let soem droplets fall onto leather (preferably flat spot) and see if it soaks in or BEADS up.
Soaks in your leather is not protected and you should use high quality leather leather products.
Clean like above with Microfiber towel moist with water. Let dry
IF nasty use a good leather cleaner, some swear by leatherique but there are others.
then get a good leather condition and put on hands and rub in - do not get too sloppy else ruins your clothes when sitting.
Whole point is to put oils and such back into leather, so it does not dry out and crack.
IF coated - anything made for car leather is fine.
Old May 11, 2024 | 02:12 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Leather does get dirty, when it gets shiny and oily looking thats when it needs to be cleaned. It is coated with a polymer top coat, so you can use any cleaner really for interiors etc. I use Renny Doyle's interior cleaner:
Amazon Amazon
I use these AutoNinja microfiber scrub pads to agitate:
Amazon Amazon
Then I treat the leather with KochChemie's leather star, let it soak in for 20 min or so and wipe down any excess with a microfiber towel:
Amazon Amazon
Do this once a month or once every two months or so and the leather will stay like new. Just using damp water won't clean the contaminants out of the leather and can contribute to permanent shininess etc.
