GLS Class (X167) Produced 2020 to present
Check engine
Old Dec 18, 2024 | 10:49 AM
Wowmichaelwow's Avatar
GLE350/W167
Check engine
Can I take my GLS to autozone for the check engine light? Appointments are days from now and as it happened in the past, the light resets itself and then they dnt find anything. It is on now and I know it will go reset by the time they see it next week.
thanks
Old Dec 18, 2024 | 10:51 AM
EWL5's Avatar
'23 GLS450
thanks
Check for a loose fuel cap. This is a common culprit!
Old Dec 18, 2024 | 12:47 PM
W205C43PFL's Avatar
Modern MBs have remote diagnostics, ask your service advisor to remotely diagnose it for you.
Old Dec 18, 2024 | 12:49 PM
W205C43PFL's Avatar
https://mbworld.org/forums/c63-c63s-...ml#post8610442
Old Dec 18, 2024 | 03:52 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
Codes don't disappear without a trace anymore. The code and milage at which it was set will still be saved in addition to various parameters at the time of the fault. If you have Xentry it will show all codes snice they were last cleared whether they are active or not.
Old Dec 18, 2024 | 10:36 PM
GLE350/W167
then why they did tell me last time that they couldn’t find any codes? I called a Monday when the light was on and on Wednesday for the appointment, the light disappeared. They told me they couldn’t find any codes or history of the check engine being on. What’s a Xentry?
Old Dec 19, 2024 | 08:32 AM
jkaetz's Avatar
Xentry is Mercedes diagnostic tool. When I got mine working and scanned our car I could see all the past faults and when they happened even if they did not trigger a warning.
I find it hard to believe that they found nothing as even our 2011 stores fault history even for simple things like a trailer light being out long after the fault has occurred. Why they said they couldn't find anything is a good question.
Old Dec 19, 2024 | 03:07 PM
chassis's Avatar
2017 GLE350 4MATIC
thanks
Yes, you can take your GLS to AutoZone to scan for codes (check engine light). MB dealers are lower than the bottom of the barrel, on average. Your experience is sadly normal.
Old Dec 19, 2024 | 04:38 PM
mikapen's Avatar
Most aren't. But that wasn't the question.
