FS: W210-W208 Euro Command and TV Tuner!
Yes, it does play DVD in the slot and also while in motion! You can also watch TV with the included TV Tuner. Let me know...
I have the same setup and use a 6 disc DVD changer connected to AV1 and my Ipod video connected to AV2.
The Euro Comand 2.0 does not play DVD. You would have to use the aux video line in on the TV tuner and install an aftermarket DVD player.
Also keep in mind that the TV tuner is analog, meaning that in Feb. 2009, broadcasters will be only broadcasting digital signals. This would render your tv tuner useless, unless you get a digital convertor.
I am abosolutely "sure" of my statements, like I said, I have the exact same setup in my CLK, so I know exactly what it will do and what it will not.
The "in motion" refers to the ability of the Comand to continue to play a signal through the TV input while the vehicle is moving, it needs to be programmed for this and that is what Steve does on all his units.
This setup is the best OE setup you can put into a 2000-2002 Mercedes (select models of course) and when combined with a proper bluetooth phone setup and DVD player, its a complete solution.
The MB TV tuner does accept NTSC video signals and I know some of the lit on these tuners says PAL/NTSC compatible, but it is not referring to the actual TV tuner section, only the AV inputs.
I have this in my car and it works great:
Here is my thread
https://mbworld.org/forums/audio-electronics/160460-just-installed-comand-2-0-controllable-dvd-player.html
Let me know if you need any further info.
Here is my thread
https://mbworld.org/forums/showthread.php?t=160460
Sorry we hijacked your thread Jimmy, but at least your getting free bumps
