98ML Window switch drvr side replace cost !
Old Mar 16, 2005 | 06:56 PM
JPRIZAL's Avatar
06 ML350/Audi A4 -ret C230/ML320
Just recently moved to Hawaii (Hint$$$) called the stealer and they mentioned parts and labor $600.00 to replace or repair the power window switch on DRIVER Side. Does the price sounds right ? Suggestion anyone ? ALOHA $$$$ !
Old Mar 16, 2005 | 08:03 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
The switches are all in one unit. The entire unit must be replaced. This was a common problem with the 98's. As far as the cost is concerned, 600 bucks including labor sound a little high. Should be about a 2 hour job. Do not know what the cost of the module is but they are not expensive, maybe a couple of hundred bucks.-
Old Mar 16, 2005 | 08:37 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
See http://www.grill.org/rodney/mclass/mlswitch/index.html for DIY instructions.
Old Mar 16, 2005 | 08:45 PM
gshock's Avatar
check ebay for the switches. You can usually find them for about $60. However, as I understand it the lastest part number on the switches are alot more durable than prior units.
Old Mar 17, 2005 | 11:43 AM
rizwan's Avatar
2005 SL55 AMG
Talking
Hey!
I followed rodney's instructions after my 2000 ML430's driver side window got stuck in the down position in Ottawa Canada in January (read: snow & ice). The instructions were easy to follow and i had the switch working in 2 hours. All you really need is a screwdriver.
Riz
Old Mar 17, 2005 | 06:35 PM
Radomir's Avatar
2000 ML 430
it took the Benz service person about 30 minutes tops (actually probably less) to replace the whole thing... so how much do they charge per hour over there? $1000? (assuming parts are 100.. and 500 is labor for a 30-minute job)
Old Mar 18, 2005 | 04:28 AM
mesallem's Avatar
2000 ML430
i have a switch available, its used. will give it to for 40
Old Mar 18, 2005 | 10:22 AM
sosh's Avatar
I would suggest you not buy a used or EBay switch. By getting from a dealer you are assured of getting the latest part number with all the improvements. How many times do you want to go thru this?
Old Jul 18, 2005 | 12:52 PM
ddtassoc
Guest
Posts: n/a
Window switch
Mine cost about $400 Canadian or $320 US parts and labour.
Interestingly the passenger side died 3 years ago, the drivers side died in January 2005 and the sunroof motor died June 2005.
Old Jul 18, 2005 | 07:08 PM
zeke320's Avatar
$105 USD in Baltimore MD area.
Old Jul 19, 2005 | 12:43 PM
marineboy0's Avatar
ml320
I had the same problem and followed the same DIY instructions involving taking the switch unit out, disaasembling and bending the contact so that it work. Took me about 3 hours to do. Try it - the instructions are pretty good.
Old Aug 5, 2005 | 03:00 PM
rmclos's Avatar
ML window switch
I had my driver window switch stop working. I bought a new switch unit from the dealer for a little more then a $100. Installed it myself without a problem. I was curious about why it stopped, so I took it apart, it wasn't bent contacts, one of the plastic pieces that push the contacts had cracked.
