Towing with the ML
Question, once I install the MB tow hitch, will the ML power the brakes on the trailer too? I know, it will do the brake lights, but don't know, if the brakes get hooked too..does anybody know?
The (MB) wiring harness is easy to plug in and you will probably need to use a 7 wire to 4 wire converter (if that is what the boat trailer uses.) 4 wires would also indicate surge brakes (or no brakes).
