Pedal value sensor/purge control valve
Old 05-04-2005, 06:05 PM
WienerWater's Avatar
2002 ML500,2005 Toyota 4Runner, 2006 F150 King Ranch, Kawasaki ZX1400 Ninja, 1978 Jeep CJ7
Here is a question, in regard to my CEL coming on when the idle dropped in "Drive" at a stop sign. The cable connected to the pedal value sensor is adjustable at the sensor. If a person was to bump it and turn it a tiny bit, would it be enough to affect the idle, maing it go down to far, sending a CEL, or is it not that critical of an adjustment? Also, what is the adjustment at the cable supposed to be? There is a stop built into it, so is it supposed to just just the mating surface, or is this all calibrated with a diagnostic unit?
After changing my crank sensor last week, the next day I started getting the CEL, codes 170, 173. Thinking it was the MAF. But as I recall, reaching in to change the crank sensor, I also pushed on this cable as well a bit, during the other sensor install. My point is, could it have been just on the edge of being out of adjustment, and bumping it made my idle drop down to much? I put about 1/16 of a turn on the cable, more tension on it,last night and haven't pulled a code all day driving. Or, is it coincedence and the CEL will hit again any time?
Old 05-04-2005, 06:21 PM
ML God's Avatar
it could, I have never had to change or even adjust one of those pedal value sensors. If it was out of wack it still would not set the p0170 or the p0173 code
Old 05-04-2005, 06:49 PM
Thats my thought as well, it should have nothing to do with those codes. Only thing I could think of was the idle dropping too much for that split second, causing a sudden rich value sent and tripping it. I have a new MAF, should be here in an hour or so and will just drive it for a day or until I get another CEL, and change the MAF. It was just a crap shoot as to what has happened since the way it's been sending codes this week, I was thinking I would get one by now was all. Before I change it, I was thinking of trying to clean the old one (since I have a spare new one) Been reading about methods used to clean the wire, epsecially on Porsche 928's
Thanks again.
Old 05-04-2005, 08:01 PM
Went for another drive.....CEL finally came back at a stoplight. Will change out the MAF tonight.
Old 05-05-2005, 01:31 AM
ML God's Avatar
once you change it out you need to have the adaption values reset. VERY IMPORTANT!! otherwise the codes may come back. The engine needs to start with a clean slate. You may also have driveabilty issues if not. Your local dealer can do it. It will take all of 5 min
Old 05-05-2005, 01:54 AM
mihir_d's Avatar
2000 ML320 2006 SLK 350
I have gotten with cleaning my MAF and it has worked well so far...
Thanks again.
I had read up some threads and tried cleaning my MAF on those lines...all my problems disappeard after the clean up and its been 20000 miles since then...still no problem...if you search this forum, I had once posted all the instructions on cleaning the MAF along with pictures...if I find the thread, I will post a link to it...
Old 05-05-2005, 06:56 PM
I kept the old one, and installed the new. All issues are gone now and my ML runs great!
I will clean the old one and store it same as the new arrived, in case down the road....who knows? On the old one, I noticed a small film of off white residue on the black plastic to the side of the wires. Maybe thats all that was screwing it up, letting it run fine and all, just dirty? Whatever, I am happy this is over with finally!
Thanks again for all the support.
Old 05-05-2005, 08:22 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I FOUND IT!!! I WENT through all of your posts one by one, here it is!!! I am going to try this on my ML55
https://mbworld.org/forums/showthrea...0&page=1&pp=10
Quick Reply: Pedal value sensor/purge control valve
