Wheels and Tires, will these fit?
E-CLASS MERCEDES RIMS, THE SIZE OF THE WHEELS ARE 18X8.5 AND 5X112 BOLT PATTERN TIRES ARE BY KUMHO 225/40-18 ALL SEASON TIRES, I HAVE A 2000 ML320 AND/OR WILL THEY FIT AN '04 C320?
to further explain...bolt pattern is the same off set might be different but they def wont handle the weight of the ML in any case
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
1) bolt size... E-class (W211) has 14mm bolts, same as M-class. C-class has 12mm bolts
2) weight... M-class is under 4600lbs, E55 is 4100lbs. 500lbs isn't that much difference, considering the E-class can easily carry more than that (tank of gas and two guys is about 500lbs). If you load the M-class up to full capacity, that would be an issue. It's likely that these wheels probably aren't even load rated for an E-class.
3) offset... M-class will certainly handle the offset. It can handle ET30 to ET60 without major issues.
The tires will fit a C-class but that's about it.
-s-
