Need some help
1 Post
2011 VW cc, 2004 ML350
Need some help
OK, this is my first post, but I've been around for a few days reading alot of your writings and learning quite a bit. I found this place seeking a little troubleshooting advice on my '01 ml430. I got a load of wet gas the day after a pretty nasty strom last week. Had a bunch of codes spit out. Basically I had random misfires all over the place, and it was running like butt. Got all that crap out, ran some gas drier stuff and injection cleaner, and filled her up with good fresh premium. Ran a lot better, but still a misfire cylinder 1. OK, my diagnostic lobe goes into effect, check plugs. Plugs not bad, but I gave them a good cleaning. No change. Check wires, both are right about 2.2kOhms, seems OK. Re-install carefully, no change. Check coil, I swapped the #1 and #2 coils. Cylinder #1 now fires like Trump, miss moves to #2. Just to make sure, I move them back, miss goes to #1 again. Each time I do any of these tests, I make sure and erase codes, test drive, get new codes, and repeat. Again just to make sure. So I figure the coil originally at #1 is no good. Order new coil, $100. Install, and it still misses on #1. Arghh! I'm leaving for work soon, and I'll be spending my lunch hour today repeating my tests, cleaning plugs, swapping coils, etc. When I get home, I hope to find a bucket of accumulated knowledge and wisdom here to give me new directions if my efforts are fruitless. Of course, I may be reporting success, in which case I will be exceedingly happy. Any and all ideas and suggestions are welcomed and encouraged. I'll test and examine everything on which I can get my hands under the hood. I don't want to have to go to the stealership and admit defeat. They'll probably replace all the coils, plugs, and wires and charge me $2000. And my luck that won't fix it! Thanks in advance for your time and mental energy on this subject.
Paul Danner
Paul Danner
1 Post
Originally Posted by ML God
Change the 2 wires for the faulty cylinder. They go bad all the time and sometimes it wont show up on a ohm check
Paul
1 Post
Buy OEM but you dont need to replace all of them. Only the cylinder that is misfiring
OK, cool. I'll need to check the letters for #1. Memory says I need a 'G' and an 'L', but I'll double check b4 ordering. Thanks again for all the help!
