ML320 rear sway bar
ml320
ML320 rear sway bar
I have searched the web and this site and come up blank with info on rear sway bar kits to replace the stock bar. I want to replace both the bar and the linkage as the linkage on one side broke and I would like to reduce body roll.
A previous posting suggested shox.com but they do not appear to list the it.
Your help is much appreciated.
98ML320
RE: sway bar
Hi Marineboy0
ML350 has newer sway bar than my 98ML320 model.
diameter 20mm <-- 19mm
I had my ML320 replaced new front and rear sway bar.
I feel a bit redeced body roll.
ml320
Thx for the info.
I actually just got a msg from shox.com that they are mistaken and H&R are only still developing the ML55 rear sway bar but it should be available in a few months. Current we are in July 2005.
ml320
By the by....
I still have gone ahead with end-links and bushing replacements. This should be the generic ones from energy suspension which can be obtained from summit racing, foraxample. The end links are about $14 a pair.
