annoying rattle
Old Jul 27, 2005 | 08:45 PM
springerfever's Avatar
1999 ML430
annoying rattle
Up till now, my ML430 has been remarkably rattle free. Within the last week I've noticed a persistent rattle coming from the rear hatch area. I tightened down the tire jack/lug nut assembly in the right storage bin and thoroughly checked that area for something loose..couldn't find anything. The CD changer + bracket was removed a few months ago. On the other side, that storage area was secure as well with only the first aid kit in that compartment . BTW, what IS that removeable plastic piece behind the first aid kit? Can't figure that one out.
This evening I removed the entire rear hatch cover to check all those assemblies..everything seems secure and tight. Anybody else had a similar rattle in this area ?
Old Jul 27, 2005 | 09:43 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
I had one that drove me nuts for 2 freakin' weeks! I did what you did, checked everything I could think of, pulled stuff apart, etc. Mine turned out to be the right rear seatbelt. My mother-in-law had removed her belt, and left it twisted and wedged between the edge of the seat back and the body. I couldn't believe it when I found it. I was ready to pull out my hair. I hope you find yours, I know how maddening it can be.
Old Jul 28, 2005 | 02:19 PM
///M3N's Avatar
Maybe it's the rear hatch that's making the noise? Try tightening/loosening the rubber stops of the rear hatch, that solved my rattling hatch.
Old Jul 28, 2005 | 02:45 PM
1999 ML430
Originally Posted by ML320Truck
Try to adjust the two nuts with rubber head on the side of the read door frame. Those two nuts controls how close the door can be shut. It fixed 90% of my tattles, the rest 10% is from the door pull pocket, some home depot felt took care of that.
Can't believe I never noticed or adjusted these before ! It took all of one minute to adjust both of the bumpers and like magic.....no more rattle !!!
Thanks for the tip!!!
Old Aug 4, 2005 | 07:53 AM
Bluefin's Avatar
ML500
Rattles
I'd put felt pads on the ends of the stoppers and also greased the threads and got rid of that rattle and squeaks
