Hey can anyone tell me how to change my own oil?
ML 500
Hi can any one out there tell me how to change my oil on my '05 ML500 or lead me to a site that can tell me? and what kind of filter i need to use and the kind of oil the sticker under the hood say mobil? what the recommended milage to change it at? I know these are all probably under my manuals but i lost them
https://mbworld.org/forums/c-class-w203/91321-05-c230-diy-oil-change-questions.html
https://mbworld.org/forums/e-class-w211/87446-oil-change-interval.html
https://mbworld.org/forums/c36-amg-c43-amg-w202/85703-how-oftern-do-u-change-oil.html
Take a look at those links, although they won't teach you directly how to change your oil, it's a good start, and from there you should be able to gain some valuable information.
Now kinda unrelated to it, are you changing your oil because you are just that kinda person (DIYer) or because it costs money at the dealer to change it since Mercedes ended the free maint. program?
ML 500
Totally understandable.
Now, you do know that your car will tell you when it needs an oil change? It's a feature for Mercedes' FFS (Flexible Service System) and will tell you when you need Service A or B.
However, depending on the service, it's not just an oil change. It's actually a checkup on various things. Would this help justify the trip?
http://www.mbeugene.com/mbcenter/b/s...questid=325550
There's a link from a dealer themselves about what goes on in the services.
ML 500
Originally Posted by billiam8d
Yes i do know what the FSS is, I have a 1998 ML350, it only got 60,000 on it O_o, but I didnt know the FSS also told me when to change my oil too, thanks
I hope I haven't thrown you off your quest to find out how to DIY oil change on the ML. That wasn't my intentions.
ML 500
Ah gotcha, I thought you were new to the Mercedes' world.
If you stick with dyno oil, the I'd advice you to do the 50 mile drive every two oil changes, or DIY the conplete A or B service which, I stress again, is more than an oil change. It's not much more than an oil change but it's more than an oil change. I don't have the spec A and B service for MY98 but I have for MY02 and MY05. If you want it, PM/email me.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Originally Posted by Darkmann
I didn't think the FSS worked that way for MY98 through MY01. Be careful here and check your manual - remember the oil sludge problem ML had to settle a law suit for? You're using Mobil-1 synthetic I hope. At what intervals do you intend to be doing the oil changes? With the synthetic, you can go as far as 10K. With dyno, I'll stay at no more than 4K between changes. Remember also that the A and B service are more than oil changes alone. Check your owner's manual for the items that have to be checked.
first of MB change the system from FSS to Mercedes Benz Maintance system for the 05 models,
so the 05 models don't have that FSS anymore,
second the 350 didn't exist until 03,
so it's either from 03-05,
unless he has a 320 that exist during 98
ML 500
ML 500
which car do you have,
do you have the 500 or 320,
the 320 does have the fss,
which model year do you have?
then your model has the Mercedes Benz Maintaince System not the FSS anymore, MBUSA said that for all 05 it is the MB Maintance System,
scrow towards the buttom and see what MBUSA says for the 05 models,
http://www.mbusa.com/brand/container...aintenance.jsp
ML 500
wow thanks alot did not know that
