Service B
Old Sep 21, 2005 | 09:18 AM
VTBenZO's Avatar
ML320
Service B
My ML320 requires 'service B', does that have to be performed by the delaership or could a local Midas perform it.
thanks
Old Sep 22, 2005 | 09:01 AM
peid's Avatar
2001 ML320
Nothing HAS to be performed by the dealer, especially if out of warranty.
Both are glorified oil changes with a check here and inspection there.
Old Sep 22, 2005 | 10:18 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Both the A and B service do include oil changes. However there are a number if items to be inspected during these services. To maintain the reliability of the car they should be looked at with corrections as necessary. I do not think I would trust a Midas or such to do this. My take is a dealer who knows what to look for or if you cannot afford that a good independent that works on lots of MB's would be the place to go.
Old Sep 23, 2005 | 10:42 PM
MBtech1's Avatar
2011 C 300 4-Matic
If you do take your car to a side shop to do the service, be sure to change the dust filter for the HVAC. A lot of people forget about this and it will eventually burn up your blower motor because it will get clogged and not allow airflow which helps cool the blower motor. Plus your air coming out the vents will start to smell.
Old Sep 27, 2005 | 08:53 AM
VTBenZO's Avatar
ML320
Thanks for the replies.....I took it to the dealer and got done with it.
