00 headlight problem
Old Dec 19, 2005 | 02:42 PM
zwhore's Avatar
hi,
i am having problem with my left headlight working. bulb is new.
i need ot know where the fuses and or relays for the lights are located in this thing.
i dont normally work on german cars,i am ase cert tech and specialize in japanese stuff.
agian just need to know where everything is at. its an 00ml320.
thanks
tony
Old Dec 31, 2005 | 02:10 AM
mcphere's Avatar
2006 ML500
Fuses and relay diagram...
There are two locations where you can find the fuses and relay diagrams. The diagrams are normally on the inside portion of the cover.
I found this instruction on my 2002 ML500 manual.
First location should be in the engine compartment on the right hand side next to the windshield washer container. You have to release the two clamps to open the fuse box cover.
The other one should be located in the front passenger footwell. Use a quarter to gain access to the fuse box by turing both the locks counter clockwise 90 degrees and remove the cover.
Good luck!
