ML320 drive shaft replacement
I have a '98 ML320. The propeller shaft ( better known to us laypeople as the drive shaft ) was originally replaced under warranty at 43k miles. Now at 96K it is grinding again. This time it appears I get to cover the expense out of pocket. Has anyone else had this replacement or am I just Lucky?
2002 ML320
I've never heard of anyone having to replace that on an ML before. Definitely not a common problem like the rattles, window switches, fuel pumps, etc. that plagued many ML's. You might just be the "lucky one."
