Door lock problem (I think)
Old Mar 13, 2006 | 08:19 PM
AsianML's Avatar
2007 E63
Unhappy Door lock problem (I think)
Okay, I've been noticing it for a while now. Whenever the doors lock, like when the car gets to 10 mph, I hear some sort of noise coming from the rear.
It sounds like the door lock. but I'm not sure which one. I'm guessing it's probably the fuel filler door, or the rear gate.
The noise sounds like, some sort of motor or something "over turning" or something like that. Kind of like a drill, where you set it to the lowest setting and drill something hard, and the drill stops the motor keeps trying or something.
It's very close, but it seems like the thing keeps going after it locks. I figure it's the locks after learning that the ML ahs electric locks.
Well, that's the best i can describe the situation. Any ideas?
(We're out of the warranty, so if some sort of repair might be needed, about how much?)
Thanks.
Old Mar 13, 2006 | 08:29 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
figure out where its coming from first... listen while someone manually locks and unlocks it
Old Mar 13, 2006 | 08:42 PM
AsianML's Avatar
2007 E63
It's coming from the rear, I'm sure.
I don't know whether or not it's the fuel filler flap thing lock, or the rear gate/hatch lock.
It's pertty hard. I'll try and figure it out later.
Thanks.
Old Mar 14, 2006 | 11:07 AM
55fanatic's Avatar
You should have someone lock and unlock the door while you stand first next to the fuel cap and then next to the lift gate...
Old Mar 14, 2006 | 07:18 PM
AsianML's Avatar
2007 E63
I went outside and tried to recreate the sound. At first you won't hear anything, but after locking and unlocking many times in a row, I can hear it.
So far, I can figure that the noise happens after it has been used a lot. I usually hear it when we go shopping or something, and the locks are always used.
Old Mar 20, 2006 | 12:20 AM
MBtech1's Avatar
2011 C 300 4-Matic
Find out which lock its coming from and replace the lock actuator.
Old Mar 20, 2006 | 06:31 PM
AsianML's Avatar
2007 E63
Uh-oh, how much do those go for?
I found out that the sound is coming from the rear hatch/gate/door.
The dealer did work on the rear defogger a month ago. Could working on that have affected the lock in any way?
Old Mar 20, 2006 | 08:38 PM
Militant-Grunt's Avatar
95 Audi urS6 Quattro
The actuator in my LR needs to be replaced in the drivers door, its 160 for the part and like 110 for labor.. Tho surely mercedes is more expensive haha.
Old Mar 20, 2006 | 08:49 PM
AsianML's Avatar
2007 E63
Is there any possible, imaginable way that the dealer people who worked on the rear door could have somehow damaged the actuator?
How soon until you think it's gonna go out?
Old Mar 20, 2006 | 11:30 PM
MBtech1's Avatar
2011 C 300 4-Matic
I highly doubt it. They just go bad sometimes and thats exactly what they do when it happens. They jump up and down rapidly. There isnt really anything you can do to it by working near it to cause this. I cant really remember how much they are to replace but the good thing is that its easier to change out the rear one than the side doors.
As far as it going out, it shouldnt. I have never seen them just stop working. The main problem is that if it jumps up and down and then stays in the unlocked position, it can make the other doors stay unlocked too. Worst case if you dont use the rear hatch too much, you could pull the rear hatch cover down and unplug the actuator. The power lock wouldnt work on the rear hatch but it shouldnt affect the side doors then. I have never tried this but it should work.
Old Mar 21, 2006 | 09:45 PM
AsianML's Avatar
2007 E63
I really don't want to see the bill for this. Darn stealers.
