13 Pin Connnector?
Apparently my AT pan needed a new gasket and a 13 Pin Connector replaced cause of some minor leak......
- remove connector and the pilot bushings next
- drain ATF at the pan
- remove oil pan and filter
- lastly, electric control unit(about 10-20 bolts) attached to the hydraulic unit.
Very happy with the work. I was also releaved of $500 bucks.
This appears to be a common problem with our trucks.
RAN
