BRAKES Please Help
1. After removing the brake caliber, do i need to remove the brake fluid line or leave it attached?
2. Torx 40 will remove almost all of the bolts on the front and rear?
3. after I remove the brake caliber, how difficult is it to remove the front and rear Brake Disc?
Please help, I am tryin to gather all of my info for this brake job. Any instructions or suggestions would be greatly appreciated...
Thank You, and wish me luck...
http://www.petefagerlin.com/ML/brakes.htm
Do not take the caliper apart with Torx. No torx is really necessary for the job with the exception of maybe the rotor retaining bolt. Mine was an allen (OEM) and the replacement that came with the new rotors was a torx.
